How much oilflow- or pressure does a turbo need?
I'm fitting a Volvo T5 turbo (can't remember the brand just now) to an old bike.
The bike has a low pressure oilsystem so not enough to feed the turbo.
I've modded the sump and fitted an electric pump to feed the turbo but that has way to much flow so I need to restrict it, question is by how much?
Does anybody know how much flow and/or pressure this type of turbo needs?
Ben
Which model is it from? They use Mitsubishi TD04 turbos, 850's ran a 15G, V70's then moved to a 16T, there's also the 18 and 19T from various R models. I can't help on the oil pressure but that might give you a bit of Googling power.
Ben
I'll ask on a couple of Volvo forums for you to see if anyone knows.
Ben
Apparently the TD04's actually have a built in restrictor so it shouldn't matter too much on how high the pressure is set to.
Hope this helps.
Hope this helps.
What electric oil pump are you using, and how have you determined it supplies too much oil ?
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
CrOwSoN15
18
22-08-2015 10:24 PM
