engine power
Old Jan 22, 2015 | 11:49 AM
cos elle's Avatar
cos elle
Default engine power
Hi i have a standard cosworth engine with
200 block
4wd head
Group a head gaskit
AB07 inlet can
2wd exhaust manifold
Garrett gt3076
83lb injectors
Escos BT inlet manifold with 12mm spacer
Air injector
Rs500 intercooler
S/s exhaust
is going to be live mapped
What power should this make
Old Jan 22, 2015 | 12:03 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
200 block
4wd head
Group a head gaskit
AB07 inlet can
Garrett gt3076
83lb injectors
Air injector
Rs500 intercooler
S/s exhaust
My bet is that it is 450 - 500 bhp possible but the RS500 intercooler might be the weak link, I believe that you can get 30 degree lower intake temps with the spec R equivalent which is actually smaller and then allows more air to the front rad or air filter. (based on What Mark Shead has said and written many times)
My engine was held back by the intercooler at 478bhp (mine is an RS500 one) and the next step really is to port the head, swap the cam and then pocket the pistons to suit. I am on a Borg Warner twin scroll.
I would imagine that whoever is going to live map it will know much more than I can tell you though.
Old Jan 22, 2015 | 12:19 PM
cos elle's Avatar
cos elle
Default intercooler
Its a pace 500 style intercooler
i would be happy with 450 or above
Yeah i'm going for a full rebuild with ported head and pocketed pistons and so on next winter
Old Jan 22, 2015 | 03:15 PM
LHD220Turbo's Avatar
LHD220Turbo
a better inlet, intercooler & a worked head will work wonders
Old Jan 22, 2015 | 03:54 PM
cos elle's Avatar
cos elle
Hi mate what spec is your engine cheers
Old Jan 22, 2015 | 03:58 PM
Staffi's Avatar
Staffi
Who's mapping it for you bud??
Going by your Spec I'd say you'll achieve 450, maybe a bit more and with the AB07 torque should be nice too.
Box, diff and brakes is maybe where you need to be looking too
Old Jan 22, 2015 | 03:59 PM
scoooby slayer's Avatar
scoooby slayer
I would suggest with a lot of midrange boost it will surge its tits off, I ran a t4 with a stock ports head but bd14 cams and boost was limited to 22 psi below 5600 rpm due to horrendous surge, it was really bad.
and if you have a stock diff and any grip the diff will leave the building first launch
Old Jan 22, 2015 | 04:35 PM
gjh's Avatar
gjh
I'd say it would be a good 450 too.
Old Jan 22, 2015 | 04:41 PM
cos elle's Avatar
cos elle
Hi motorsport development will map it
i have
ap 4 pots with 330mm discs
300mm rears
A1 rallysport uprated t5 gearbox
7 1/2 Quaife Dif
6 degree beam
gaz gold colovers
so on
cheers
Old Jan 22, 2015 | 04:44 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Totally standard internals, 1000cc injectors, vipec ecu with coil on plug, Borg efr on twin scroll manifold and custom exhaust.
It killed the std box within 100 non aggressive miles and mine was a low mile box. The Borg does spool up much faster than a gt3076 and makes lots of low down torque.
I have also gone for a Supra diff conversion. I will need to now spend over £4k on an opplliger box
Mine is 4x4
Old Jan 22, 2015 | 04:46 PM
cos elle's Avatar
cos elle
Hi i think it will be ok as the turbo has a Ported Shroud
diff sorted
cheers
Old Jan 22, 2015 | 05:00 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
my T4 engine with lots of mid range boost so if the Spec is right you can do that. Its nothing to do with ported shroud but cam choice. This was back in 1999 so its been possible for a long time. Great engine maybe the best I ever had.
Old Jan 22, 2015 | 05:06 PM
Mark Shead's Avatar
Mark Shead
Without head work it will be a compromise and will need to be live mapped to cap boost lower down, It will feel laggy and not big on torque.
Mark
Old Jan 22, 2015 | 05:07 PM
Staffi's Avatar
Staffi
Nice and strong from 4k revs that was Rod, l bet that was sharp on the road ?
I'd be happy with that today let alone 16yrs ago
Old Jan 22, 2015 | 05:13 PM
scoooby slayer
Mark
exactly, mine was still quick but had to be trashed to death or it was pants lol
Old Jan 22, 2015 | 05:18 PM
scoooby slayer
I was running a pair of bd14s rod but standard ports, the point im trying to make to the op is with a gt3076 and standard port head it wont make big mid range torque it will be a compromise with boost capping, well either that or a feckin surge monster
honestly my t4 at 2.2 bar below 5600 rpm it sounded horrendous, I wasn't sure what it was to start with, until I watched the boost gauge and saw the boost jumping from 22 - 32 psi rapidly
I didn't mind as I bought it built and it was the right price but I certainly wouldn't want to go to the trouble of building an engine for it to turn out like that.
Old Jan 22, 2015 | 05:55 PM
cos elle's Avatar
cos elle
Default bhp
Ok will this make 450bhp and be drivable as a road/track car
Old Jan 22, 2015 | 06:12 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Yes it should. The enjoyment on the road would just be better if it had the beadwork done or better still use the more moder pm turbo like the twin scroll. Lag can feel fast but makes the car harder to drive and maintain speed.
Old Jan 23, 2015 | 06:22 PM
cos elle's Avatar
cos elle
Default head
how much would it cost to have the head ported?
cheers
Old Jan 24, 2015 | 07:48 PM
LHD220Turbo
cheers
http://www.roperdevelopments.co.uk/
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Ben26
Aug 27, 2015 08:56 PM
IAN RS2k
Aug 18, 2015 07:51 PM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
