Airbag light, MOT fail?
Ben
I need to get the Pumarse MOT'd but just remembered the airbag light is on due to running harnesses, so no pre-tensioners!
Is the dash light a fail?
Ben
Poop.
V reg mate.
So hypothetically speaking, if the bulb in the dash mysteriously stopped working /disappeared, that would just be an advisory?
V reg mate.
Certainly here in Northern Ireland, 2001 onwards the lamp must work as expected.
Pre 2001 as not all cars had self diagnostics for SRS systems, you would get away with no lamp at all.
i dont think it is a fail in england, mine has gone through 3 mots at different garages with the airbag warning light on (it goes through a sequence of flashes and then stays on permenantly when you turn on).
Gary Krishna
These might work
http://m.ebay.co.uk/itm/251652951391
Says they're for a focus but they might work on a puma or they may have some for a puma.
Ben
I actually bought some resistors to use a while back, but the soldering iron packed up so never got around to it
airbag lamp fails if its on. if it doesn't illuminate at all its a pass and advise
but you might get pulled on the missing pretentioners,
this might help.
http://www.motinfo.gov.uk/htdocs/m4s05000401.htm
cheers nick.
this might help.
cheers nick.
TPM961
15-01-2018 10:50 AM
The Enigma
12-09-2015 10:12 PM
