Help needed Audi tech's
Old Nov 3, 2014 | 11:50 AM
jamie956's Avatar
jamie956
Default Help needed Audi tech's
Car in question is an Audi A6 1.9tdi 2004,
Car was missed fueled with approx £20 of petrol ontop of £5 deisel, then driven for 1/2 mile, car stoped and then wouldn't re start realising the car had been missed fueled stopped trying to start it,
Tank was draind with a vachum type tank sucker and a new filter fitted and 20ltr of fresh deisel, system bleed and car started and run for a few miniutes, then test driven for a few miles.
Now when ever the car is stopped for a few miniutes it becomes difficult to re start has to be turned over for a while, so then decided to change non return valve on top of the fuel filter, but this has no affect.
Anyone have any other ideas or susgetions it deffently feels as if the fuel is draining back, once car is running its fine.
Thanks
jamie
Old Nov 3, 2014 | 08:36 PM
Piston Broke's Avatar
Piston Broke
Needs more running nothing more I would say. We get them where I can take one of my lads a good hour of driving to sort itself
Old Nov 3, 2014 | 09:51 PM
botters's Avatar
botters
competant bodger
are the fuel pipes on the filter housing on the correct way they can be a pig to start if not i know from....erm.... experience lol! they are usually coloured at the ends so you would think it was nigh on impossible to mix them up lol
Old Nov 6, 2014 | 02:10 PM
american's Avatar
american
baseball and apple pie
-pump is fried, replace fuel-pump.
Old Nov 6, 2014 | 04:13 PM
slammedorion's Avatar
slammedorion
Could try brimming the tank and adding 300ml ish of 2 stroke oil?
Will help lubricate the pump...
Old Nov 6, 2014 | 05:47 PM
Harryh24's Avatar
Harryh24
I'd say either pump or injectors fried
Old Nov 6, 2014 | 06:13 PM
john_3.0s's Avatar
john_3.0s
Did you flush the filter and its housing through with free
Sh diesel? I'd run it for a good few hrs before you do anything. If you disturbed any fuel lines it could be an air leak too causing the tricky starting
Old Nov 6, 2014 | 06:37 PM
jamie956's Avatar
jamie956
Its starting 9 times out of 10 now so I just think it needs a good tank full running through it to clear any remaining petrol out, in Hine sight should have taken the tank out I made sure it was completely empty.
Old Nov 6, 2014 | 07:23 PM
Fullflush's Avatar
Fullflush
Glad it seems to be getting better
JoeyBoyden
Jan 4, 2024 02:36 PM
cos elle
Sep 1, 2015 06:48 PM
Bailes1992
Aug 16, 2015 07:14 PM
M K
Aug 12, 2015 06:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
