Cos fuel pump voltage...........
Got 14 volts at battery,13.8 volts at fuse for pump,but only 12.2 volts at the pump
Is this ok or do I need to re-wire the pump threw a relay??????
Thanks
Thanks
Every saff i have tested has had 11.5-12.3 to fuel pump - aint enough.
Needs rewiring from a 40amp relay and a 30 amp fuse using min of 25amp wires
Also needs the earth re-wiring.
Should make 13.3 min with 14 @ battery then.
13.3 is min voltage for a 044 pump anything above is a bonus
JK12
33
26-04-2021 12:09 PM
DixieTheKid
11
06-06-2020 11:20 AM
