cosworth engine rebuild
hi all
i have a sapphire 4x4 and want to get the engine rebuilt
i from manchester area
can anyone suggest a good pace local to get it done
thanks all
thanks all
You need to pick the engine builder very carefully. If you can get it out of the car yourself then I would try to ignore the geography and send it to a recommended and trusted source, a badly built engine (especially Cosworth) could cost £3000 and then much more again to have the remedial work done if it lets go. Just hire a van and go on a road trip or maybe stick it on a pallet / call a courier
I would personally recommend Mark Shead at MAD developments.
I know Harvey Gibbs has a good reputation. You may find that Reyland can recommend someone now that they do not do this stuff anymore and I expect MSD could sort you out.
A rebuild done right is £3500 before you do any upgrades. It is worth having it long studded whilst apart and consider pistons for a bigger cam whilst it is apart.
Live long and prosper!!
I'm in the process of doing one. But if I was to let someone else do it I'd be happy to send it to Harvey Gibbs, Mark Shead, or Tony. All have good reps.
As a note said above do what you can now pistons valve pockets, long studding etc etc.
Paul
big_Rad
15-09-2017 09:36 AM
track.focus'd
12-08-2015 05:53 PM
wheelwizardrefurbs
04-08-2015 06:23 PM
