Bolts
Hi guys how clean do you have to get nuts & bolts before you send them off to be zinc primed???? I've soaked them in thinners all day so all the wax oil has gone but they are a tad rusty & black looking.... Any help would be grate.
Cheers in advance.
Cheers in advance.
they acid clean them anyway fella u done what you need degreasing them they will do the rest if you blast clean them it makes the plating dull leave em as they are if u must do anything buff them up on a wire wheel
You will need to remove as much of the rust from the bolts as you possible can with a wire brush before taking them to the zinc platers.
Most good zinc plating companies have acid dipping tanks to prepare items prior to plating.
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
