S max starting problem
Old Dec 18, 2013 | 07:55 PM
P4ULT's Avatar
P4ULT
Default S max starting problem
Our s max has recently started to give us an intermittent problem when trying to start it. It tries to fire but doesn't, then if you leave it 10mins it starts fine. It's only happened twice but would be good to get it sorted.
Any ideas please
Old Dec 18, 2013 | 09:20 PM
studabear's Avatar
studabear
Any fault codes stored?
Old Dec 19, 2013 | 12:07 PM
LHD220Turbo's Avatar
LHD220Turbo
petrol or diesel? year?
Old Dec 19, 2013 | 07:55 PM
P4ULT's Avatar
P4ULT
My bad 1.8tdci. Dunno about fault codes.
Old Dec 19, 2013 | 07:59 PM
Bailes1992's Avatar
Bailes1992
First job would be to get it plugged in then!
How does it sound cranking? The ECU won't inject until the engine is spinning a certain speed. If the starter was on it's way out it could be causing your issues.
Old Dec 19, 2013 | 09:47 PM
DangerousBryan's Avatar
DangerousBryan
Would definately check battery and starter.
Old Dec 19, 2013 | 09:51 PM
creator's Avatar
creator
Check the glow plug wire mate they normally burn out
Old Dec 20, 2013 | 09:18 AM
Bailes1992's Avatar
Bailes1992
Never heard of that on a Lynx?
Also the Lynx doesn't need to run a glow plug cycle to start! Mine starts instantly after 1 crank!
Old Dec 20, 2013 | 10:17 AM
Milkybar Kid's Avatar
Milkybar Kid
Best look on here
http://www.smaxownersclub.com
Old Dec 20, 2013 | 11:35 PM
trigger-'s Avatar
trigger-
scrap it, one less people carrier on the road
Old Dec 21, 2013 | 02:16 AM
botters's Avatar
botters
competant bodger
as mentioned above slow starter can cause this, they dont often even sound slow until you compare it to one with a new starter!
Old Dec 21, 2013 | 07:31 AM
P4ULT's Avatar
P4ULT
Cheers all. It's been fine since, fingers crossed.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
nick8saff
Aug 16, 2015 05:35 PM
Zoggon
Aug 10, 2015 10:39 AM
Sjieter
Aug 5, 2015 09:47 PM
