ignition can it just retard
Old 22-03-2005 | 05:36 PM
abdr500's Avatar
abdr500
Default ignition can it just retard
can ignition timming just retard or get stuck on retard mode or is the any thing to look out for as to retard of the igntion as my car feels like its gone in to retard mode its a stage 3 2wd cossy and feels like it be strangeld
Old 22-03-2005 | 05:41 PM
ECU Monitor Enthusiast
Could be anything !!
Dont drive it hard, get it checked by a proffesional before you break it !
Engine rebuilds cost thousands.
Most likely a sensor failure.
Coolant(blue) , Map sensor, Charge air (brown) or the throttle position sensor.
Old 22-03-2005 | 05:49 PM
abdr500's Avatar
abdr500
SECS, had it at a rolling road and all they could see wrong is the igntion lead have to much resistance but all my sensor are brand new 2 month ago i mean every thing. it still boost up the same but just dont pull and even the tone of the engine sound differnt when your trying to go up into the revs befro it would just snap in to its revs realy fast but now it goes but sounds strangeld or it just tugs in in at high revs
Old 22-03-2005 | 06:05 PM
Still could be a sensor problem. !!!
A very remote possibility.....
I have had my car with a worn crank pulley which caused bad ignition retard.
This is what the ecu uses as a timing reference.
The woodruff key had worn away and the pulley was loose retarding the ignition
by about 15 degrees.!!!
The pulley was firmly bolted on too !
I would still recomend taking it to a specialist or someone local who knows what they are doing !
Old 22-03-2005 | 06:47 PM
abdr500's Avatar
abdr500
SECS,the thing is ive checked the timming the 2 top arows on the cam pully are spot on and the piston number 1 right at the top and the rotor arm is pointing spot on with the mark on the rim. so nothing looks worm around the timming pully and
Fiddy
21
29-09-2015 06:10 PM
beller
21-09-2015 04:13 AM
marky_g
12-09-2015 04:26 PM
Marino
12-09-2015 11:10 AM
morg65
Escort MK 5 / MK 6
11-09-2015 01:55 PM
Quick Reply: ignition can it just retard
