Ztec turbo runing lumpy
Old 26-09-2013 | 08:18 AM
Ztec turbo89's Avatar
Ztec turbo89
Default Ztec turbo runing lumpy
fiesta mk4 2.0zetec as follows: -2.0 zetec blacktop engine, running OFAB management. -T4 Turbocharger with front mount intercooler, -Port and polished head, -steel spacer plates to lower compression -Two focus RS head gaskets -Rs turbo gear box, brakes, drive shafts. -Cosworth beige injectors -full decat custom exhaust system, -Walbro Fuel pump -leather recaro seats, Too much to list, to finish this project off, i have been informed that the ecu will need to be mapped in order to run the engine smoothly, as at the minute the Engine is running lumpy as the air/fuel ratio is out of sync. Wht wud the main causes for runing lump i mean worse case wht wid it be or take to run proply cheers if any 1 can help
Old 26-09-2013 | 03:25 PM
mk1trb's Avatar
mk1trb
Boost Junkie
cam timing slightly out casues rough running but your injectors wont be any use on a 2.0zetec turbo so could be running lean on idle, and yes you'll need to get the ecu mapped
Old 26-09-2013 | 05:30 PM
nevsrevs's Avatar
nevsrevs
get it mapped/new management
Old 26-09-2013 | 06:44 PM
project rs's Avatar
project rs
why have you used two head gaskets with spacer plate
Old 26-09-2013 | 06:48 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
he should do, it's the same principle as if you were fitting a normal head gasket. To create a seal.
But as above get it remapped. What injectors you using btw?
Old 26-09-2013 | 06:59 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Beiges don't really go too well on a zetec turbo there ok but tend to run lean, I'd take it to a tuner and see what they suggest as they may be able to us your setup and make it run smooth, or recommend good managment/components
Old 26-09-2013 | 08:07 PM
rsmark86's Avatar
rsmark86
Wrong chip, wrong injectors
You need a zetec turbo chip and a matched injector too the chip, msd sell these for £250 for the chip, totally wrong ignition and fueling for a zetec when running cvh chips
Just a tip, check out boost monkeys ofam ecu, plug and play with your loom and fully mappable, £389.99, this way you can pick your injector before mapping.
And another, why use spacer plates, when a st170 bottom end and focus rs 1.8mm head gasket with your head and st170 valve springs is proven over 300bhp
Why would you bother?, it's a ticking time bomb at 200bhp, also a t4 turbo is too big for the spec, a t3 from a cosworth would be better
Old 26-09-2013 | 08:19 PM
gingerturbo
It seams pretty thrown together really don't it? It's not a bad setup just needs an expert touch
Old 26-09-2013 | 08:23 PM
frsjon's Avatar
frsjon
doesnt say its chipped at all as said above its a bit of everything thrown together by the sounds of it. dump the frst ecu and get something modern and mappable
Old 27-09-2013 | 09:37 AM
rsmark86's Avatar
rsmark86
Yeh, I would use a stock rst t3 for that spec, with a decent chip/ecu to run it, that way 10psi will be the limit at around 195/200bhp, that way it should be ok
Otherwise I would stick the st170 valve springs and bottom end in
stevierob
07-09-2015 07:09 PM
RSBryden
06-09-2015 08:39 PM
cozzzzy power
04-09-2015 08:14 AM
turbowag
03-09-2015 08:07 AM
Jerry Ryan
02-09-2015 08:02 PM
Quick Reply: Ztec turbo runing lumpy
