Baffled sumps...........
Old Mar 19, 2005 | 09:04 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default Baffled sumps...........
what are they and what is done to the sump
im having a alloy sump made up and wonder if i could get the chap to get it baffled?
is it just the case of having plates welded in to stop the oil swirlling about?
will be for a S2 track car
Thanks Radders
Old Mar 19, 2005 | 09:44 AM
AlexF's Avatar
AlexF
A baffles sump is like a series of barries in the sump.
It stops the oil all gathering on one side when you go round a long fast corner....
If you think about it the engine oil pump only collects oil from one point in the sump... if theres no oil at that exact point ALL the time then it will not suck up any oil and will starve your bearings of oil!!!
for example
you can see the area at the back is were the oil pick up goes... and you can see as std the area is baffeled a bit
Alex
Old Mar 19, 2005 | 10:07 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
My sump was baffled by APT, I also had a modified oil pick up fitted too.
Old Mar 19, 2005 | 10:15 AM
AlexF's Avatar
AlexF
do you need one for track thou...
AndyRST doesn't seem to get any problems...
Alkex
Old Mar 19, 2005 | 10:20 AM
Tony Turbo's Avatar
Tony Turbo
No offence, but Andy's car isn't as powerful as the cars we are talking about, and how do you know he doesn't get any problems, he doesn't have any gauges
Better safe than sorry
Old Mar 19, 2005 | 10:21 AM
Charlie Chalk
Unknown.
i thought they was better as you can suffer from oil surge on corners on track
Old Mar 19, 2005 | 10:24 AM
Charlie Chalk
Unknown.
LOL @ no gauges
my car once finished will be 270/300, got fully adjustable suspension and will handle VERY well, so just making sure it'll all be safe
Old Mar 19, 2005 | 10:27 AM
AlexF's Avatar
AlexF
but not all cars suffer......
old x-flow ford lumps do VERY BADLY!
But as andys is still running it cant be that bad can it?!
Alex
Old Jun 16, 2009 | 08:36 PM
projectcabby's Avatar
projectcabby
Hi, I blew up my 2 litre zetec as it does not like much oil, just over minimum left in engine after each stage at croft this june, it just throws it into my catch tank.
i have no return feed to the sump, would this solve me killing bottom ends on the track or do i need a bafflelled sump?? dry sumps are very expensive??
Any advice out there??
Old Jun 16, 2009 | 08:45 PM
Red16's Avatar
Red16
fuckin hell... this thread is 4 years old
timsrs
22
Sep 24, 2015 08:14 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
little bram
Sep 21, 2015 02:50 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
