Any bmw boffing on?
Just looked at a e46 323i for a mate and the clutch pedal has gone rock solid! Is there a known problem with them jamming up on the hydraulic side or is it box out time???
Coldo loves seamen
Mine was doing that sometimes and sticking, it was to do with the cruise control throttle cable. It kept sticking after I had used it. Just freed it off a little and it was fine for a while.
That's the throttle pedal that sticks isn't it? Why would the clutch stick after using cruise control?
I heard its common for the throttle pedal to stick after using it, but its a simple fix
Coldo loves seamen
Cracked bleed nipple off on slave and was nice and free! ANSI took shave off and it's free with your hand so gonna drop box out thursday
yip, box out, something locked up inside there,
seen them before with the release bearing broken up and jammed up into the diaphram springs on the pressure plate
