Electric window help please!
Old Jul 20, 2013 | 05:18 PM
Ellie's Avatar
Ellie
Default Electric window help please!
Front passenger window has been a bit intermittent for a couple of years, and usually it will start working again before I've got to where I'm going, but today, it won't.
It will go down, from the passenger door switch only, so the driver switch isn't working for it either. All the other windows are fine though.
Edited- it won't come up from either side.
Any ideas?
Thanks
Old Jul 20, 2013 | 05:27 PM
stevieturbo's Avatar
stevieturbo
C**t
So it works from the pass side, but not the drivers side ?
Sounds most likely the drivers side switch faulty.
Old Jul 20, 2013 | 05:34 PM
Ellie's Avatar
Ellie
Oops, didn't even explain that properly did I!!
No, it won't go up from the passenger side, only down, and the drivers side switch won't work at all for the passenger window.
Old Jul 20, 2013 | 06:14 PM
st220kyle's Avatar
st220kyle
can you swap the passenger switch over with a switch from one of the rear doors just to see if it makes a differance?
Old Jul 20, 2013 | 06:15 PM
Brendan's Avatar
Brendan
struggling with reality
have you had the switches out and tried connected the relative wires? Also take a DVM and have a look for and open circuit on the wires, one at a time to try and fine the fault!
Do this when it is not working if poss to fine the "intermittent" fault! - this can take a while!
Old Jul 20, 2013 | 06:40 PM
Ellie's Avatar
Ellie
I'm utterly clueless with electrics and don't even know how to get the switches out and test the wires!'
Old Jul 20, 2013 | 07:26 PM
Ellie's Avatar
Ellie
Sorted it now.
It's the switch itself, and for some reason it stops the drivers controls operating the window aswell.
Stuck it on a rear window for now and ill get another one to replace it.
As I KNEW would happen, snapped the clip that holds the bit around the switch down, and the drivers door one is the same anyway so ill get them while I'm at it.
Old Jul 20, 2013 | 07:54 PM
st220kyle's Avatar
st220kyle
At least you've sorted it, I thinks that's the best outcome you could of hoped for at least it was only something simple
Old Jul 21, 2013 | 08:03 AM
Ellie's Avatar
Ellie
Yeah definitely, cheers.
Old Jul 21, 2013 | 12:37 PM
BM08's Avatar
BM08
Could have been a nightmare if this happened during winter time, because you just know the window would get stuck in the open position and not close
Old Jul 22, 2013 | 12:50 AM
Ellie's Avatar
Ellie
Guaranteed with me, in fact, it was stuck in the open position yesterday and great big black storm clouds rolled over, despite us having a sodding heat wave.
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
cossie330
Sep 27, 2015 04:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
