Ultimate CVH
Old 24-06-2013, 08:54 PM
  #81
stuart collins
stuart collins's Avatar
Originally Posted by rsmark86
what spec you going to the the yb at stu?
depends how much cash i got when got eveythin else
atm ive got ported head with bd15 and 10 cams gt35 but may change it to gtx3076 depends on cash garys doin manifold bringing turbo to the front by pass headlight prob 3.5 in down pipe and 3in system ext waste gate out front bumper , got 50mm jenvey singles with 70mm plenum and 8 injectors but dont no if it will go in so may be swedish plenum with 3in body , just need to sell the standard 205 engine i have when finished mocking up and build a bottom end if got enough cash
Old 24-06-2013, 09:34 PM
  #82
rsmark86
rsmark86's Avatar
nice one stu
i had the gt35r and loved it made at 1.6bar it made the same torque as power, i loved it, with my screamer pipe and anti lag bangs
Old 25-06-2013, 02:55 PM
  #83
StephenC
..BS Motorsport..
StephenC's Avatar
Thinking out aloud, mating a gearbox to a different engine is going to be costly, timely and probably a pain in the arse. So it would be nice to stick with a combination that were meant to actually fit. So, as was brought up earlier, what about a mk2 frs engine and box? Box is plenty strong enough and I'm sure with new turbo and management and fuelling the engine would be easy 350bhp+ and reliable with it. BUT, will that extra cylinder make the engine physically too big for the bay? Ive been trying for the last hour to find some dimensions for the engine (block) but seemingly the information isn't there to be had. Does anyone know if someone has tried it and failed or even looked at doing it and worked out any obvious pitfalls?
Old 25-06-2013, 03:13 PM
  #84
crazycage
crazycage's Avatar
ive got a mk2 focus rs head here , its 540mm long and a zetec one is 460mm long hope this helps
Old 25-06-2013, 04:10 PM
  #85
rsmark86
rsmark86's Avatar
Think you will find a mk2 frs engine and box can take 470bhp on standard internals
And the only thing that can't keep up is the standard clutch, they seem to let go above 460lbs or there abouts
To get the above power only requires
Hybrid turbo
Forge actuator
Free flowing exhaust
Cias induction system
650/750cc injectors
Up rated fuel pump
Up rated boost solenoid
Inlet plenum change
Intercooler
And to get 400bhp and 400/450lbs only requires
Cias air box
650cc injectors
Inlet plenum
Remapp
Intercooler
Old 25-06-2013, 06:18 PM
  #86
StephenC
..BS Motorsport..
StephenC's Avatar
It would be the smart option as it will handle the power and the transmission will also be capable too. Just need to work out if it will fit now. Without offering one up I cant imagine it been an easy call to make and by that point if it doesn't fit it'll be going in the boot
Old 25-06-2013, 09:21 PM
  #87
rsmark86
rsmark86's Avatar
it would be alot of work.......... my opinion would (as i would do)
fit a complete focus rs mk1 running gear with shafts and mounts from crazycage and then get a nice stack dash to work with the electronic speedo.
and for mods to get 350bhp (which standard internals are fine)
free flowing exhaust system 3"
forge actuator
grs cooler or better
siemens injectors
pumaspeed inlet cam (better low down drivability)
tubular exhaust manifold with either johnfrs hybrid or gt28
but for the sheer look and quality i would get a crazycage inlet and and over the gearbox exhaust manifold with either a gtx28 or a borg warner efr turbo to suit
and your choice of management, and it will be near on bullet proof
theres a guy on here running 390bhp with the stock bottom end
Old 25-06-2013, 09:51 PM
  #88
StephenC
..BS Motorsport..
StephenC's Avatar
^ plus we know it will fit. In all fairness it does sound like the easiest/best compromise. Whats a set of rods and pistons? About 1k? So with them in place a tune of say 350-380 would be happy all day long and should be enough for a stripped out old knacker like the sound of it, and like you say with the crazycage manifolds it would also look the part, cos in standard fettle they do look a bit gash (I know looks don't mean shit but I want to be happy when I open the bonnet).
Old 25-06-2013, 09:58 PM
  #89
mgtkr1
mgtkr1's Avatar
if it the same one, I have seen that black ''s1'' with focus rs motor/box. irc it was 270hp but was properly cornerweighted/set up and during a trackday at cadwell was visibly quicker than most stuff there that day. a really well thought out bit of kit
Old 25-06-2013, 11:00 PM
  #90
rsmark86
rsmark86's Avatar
dont think you get what im saying, the mk1 frs engine does not require any internals changing for the desired output you want
hence why i said buy a full running gear, and you can spend money on goodies to complement the conversion instead of forged internals ect
a focus rs engine with just a free flowing exhaust, decent intercooler and airfilter and actuator will make near 300bhp on aftermarket management, reason they dont on normal management is the standard map sensor only likes 1.5bar
it would be the easist conversion of the lot, no rebuild needed, you could fit it all in and get it running on your desired ecu and upgrade turbos and manifolds later
so all that would be needed is the mods above
gearbox mounts and driveshafts
a speedo set up
mod your engine mount
ecu set up
and fit a decat and mod to your exsisting exhaust system
Old 26-06-2013, 07:45 AM
  #91
project rs
project rs's Avatar
You can get mtx box's with the Speedo drive same as bc box so no need to by expensive gear plus its slightly shorter so might get away with no cutting of shell and you can drop a atb straight in and on the subject of engine I'd rather by a standard blacktop and put a set of rods and pistons in it as people want alot for rs engine and with my way its future proof should you want to up the power
Old 26-06-2013, 03:48 PM
  #92
Canada1
Canada1's Avatar
All of this discussion gets away from the main topic - Ultimate CVH.
Sure there are many ways to get a more reliable, more powerful, more modern engine into a MK4 escort.
A well built CVH looks proper under the bonnet. (just my opinion).
Old 26-06-2013, 04:46 PM
  #93
stuart collins
Thumbs up
i agree
Old 26-06-2013, 05:08 PM
  #94
gus
gus's Avatar
thats the reason im a die hard cvh fan
only a few of us left now lol
Old 26-06-2013, 05:47 PM
  #95
russ rs
russ rs's Avatar
Cvh staying in mine .
The noise on full chat the problems lol
Old 26-06-2013, 07:19 PM
  #96
Jamie_EscortSport
Jamie_EscortSport's Avatar
Sorry if iv missed a post, im under the impression stu Collins had the most powerful...is this correct? ? If not what is?
Old 26-06-2013, 07:25 PM
  #97
gus
gus's Avatar
its up there
gotta be close between him and ollie (nms)
does torques count as mine ait shabby
Old 26-06-2013, 08:08 PM
  #98
russ rs
russ rs's Avatar
I though Ollie used be a tall block and maybe a duratec block now so strictly speAking 1.6 got be stu.
But don't forget mo's if any engine
Old 26-06-2013, 08:10 PM
  #99
R-A-J
R-A-J's Avatar
from what my mates have I think that once you get above and beyond 300bhp reliablilty and drivability becomes a huge issue. Im sure everyone remembers the "DMAN" who was after the magic 300, well he got it in the end but the amount of time it held that power was a tad short.
Cant believe no one has picked up on gus's car, what are the figure again mate? post your graph pal, field motorsport created that monster and its been very reliable as far as I know, also no one has mentioned MK's mk2 fiesta again a fms creation.
I only here good things from their custromers and their cars no seem to get shouted about, just totally abused on track without issue which is a good sign of a competent tuner/build spec etc.
Project RS/CrazycageMcPumpkinsexycheeks are also a good source of info as Projects escort was at the 300 mark but with fantastic on and off boost drivability.
When Crazycage gave me a go of his fiesta at pod to drive to Tesco I pretty much threw the keys back at him at Tesco's the speed of the thing scared the crap out of me to say the least
Old 26-06-2013, 08:21 PM
  #100
CrOwSoN15
Ben
CrOwSoN15's Avatar
MO's was ZT
  #101
russ rs
russ rs's Avatar
That's the point Gus must be up there but his and Sri total diff set ups I bet so be good if Gus decide to chase the big 400 how the Graff and ability compare.
But both weapons on track, Q plates engine sits in New bay and I bet that do over 350 easy
to all these best thing all different in good ways
Old 26-06-2013, 08:22 PM
  #102
russ rs
russ rs's Avatar
Originally Posted by CrOwSoN15
MO's was ZT
That's what ment about any engine
Old 26-06-2013, 08:29 PM
  #103
R-A-J
R-A-J's Avatar
Im sure gus is over 400ftlb and the bhp is shortly behind but I may be mistaken?
Has Olli's car done anything in the past5 years? ive never seen it out and was told it blown a few times then got shelved, again this is only here say ive heard so I could be very wrong
@gus & Olli (if they are onhere) post some figures lads
Old 26-06-2013, 08:47 PM
  #104
project rs
project rs's Avatar
thanks for the comments raj but the only thing i wanted to do the little cvh was try it with a spot of nitrous to get the turbo up and running quicker to see what it felt like then but other things beat me too it and those who know me know that the new set up is far from standard but should be interesting as we know the new set up is capable of 1000bhp as many run that and more but i'll keep it sensible as its fwd when it comes down to it. the spec of my cvh was
cosworth racing pistons (7.8 compression)
farndon rods
arp bolts
t34 with both .48/.55 housings
crazycage inlet
crazycage exhaust manifold
one off newman ground cam to suit turbo
custom head by same guy who does stu collins
custom intercooler
standalone management
as raj said was running good numbers for several years being abused daily as a road car and several weekends running up the strip at pod by me and anyone willing to give it a go
Old 27-06-2013, 06:58 AM
  #105
gus
gus's Avatar
The most reliable thing about my car is that I'm never in work long enough to keep the thing on the road lol
Old 30-06-2013, 11:22 AM
  #106
russ rs
russ rs's Avatar
That feeling when put foot down and u hold on for life is worth the reliability issues lol
Old 30-06-2013, 12:47 PM
  #107
gus
gus's Avatar
i not had any un reliable issues (touch wood)
i do love the way mine screams through the revs
that could be me tho
Old 30-06-2013, 12:59 PM
  #108
russ rs
russ rs's Avatar
I agree mate but been that long since mine been on road hard to remember lol
Old 30-06-2013, 01:01 PM
  #109
gus
gus's Avatar
shit video but does make me laugh, only gave it a blip @27psi
http://s22.photobucket.com/user/s1gu...afa4d.mp4.html
Old 30-06-2013, 01:32 PM
  #110
stevenebm
post whore
stevenebm's Avatar
I can't see anything gus.
Old 30-06-2013, 01:41 PM
  #111
gus
gus's Avatar
works this end????
not alot to see just a bit of noise
was trying to hold my phone and steer
Old 30-06-2013, 05:51 PM
  #112
russ rs
russ rs's Avatar
Na not working gus
Old 30-06-2013, 05:58 PM
  #113
mgtkr1
mgtkr1's Avatar
just a dab and she lights up the tyres. like it gus, what power?
Old 30-06-2013, 06:29 PM
  #114
stevenebm
post whore
stevenebm's Avatar
Works on my ipad,didn't on the iPhone.bet that would be fun when giving it some.looks like it would spin with the slightest tap of the pedal.
Old 03-07-2013, 03:32 PM
  #115
derwynr
derwynr's Avatar
I've got a N/A CVH in the garage waiting for a new homeif anyone if interested? It's got a Ferriday fully ported large valve head,Newman phase 4 cam with solid lifters, L&B bottom end with heavy dutybearings, and powermax (if I recall) pistons.
The engine comes complete with AP 4paddle clutch, heavy dutypressure plate and RS1600i rocker cover.
Fuelling it'll come with a set of twin bike carb conversionand also a 34DMTR with 27mm chokes.
I’ve also got a custom Newman cam that I used for roadrallying that can go with it.
No longer needed as I’ve gone to stage rallying and fitted aZetec-SE in it’s place!J
Old 03-07-2013, 03:51 PM
  #116
derwynr
derwynr's Avatar
Oh, and there's also a maniflow exhaust manifold!
Old 03-07-2013, 07:13 PM
  #117
jamie's
jamie's's Avatar
i was always led to believe that zvh's aren't great due to the cvh is the limiting factor
thats why a lot of places are getting same power out a 1.6 as a 1.8/2.0
but i see jimbo at scs has just had 402bhp out a zvh so they are capable of flowing big enough power
so a cvh or zvh is defo possible even if you want big power but with the original cvh look
Old 03-07-2013, 07:57 PM
  #118
gus
gus's Avatar
People have been getting that sort if power from a cvh for years
Old 03-07-2013, 08:02 PM
  #119
StephenC
..BS Motorsport..
StephenC's Avatar
Well, ive been mulling it over and I think im going mk1 FRS engine and box. Just ticks all the boxes for me and as its been done already shouldn't take too long to get everything together. If I went EVO engine it would take forever as I don't get that much time at home at present. Im thinking crazycage manifolds (if I can get hold of him), gt28 turbo or similar and a set of rods/pistons for added reliability. Just need to choose some management for it. So, if anyone knows of an engine and box for sale please pass their details on. thanks
Old 03-07-2013, 08:35 PM
  #120
nevsrevs
nevsrevs's Avatar
if your going to be putting rods and pistons in mate then get a bogo 2.0 or buy a frs lump and leave it on standard internals as these are ok at 350+
Quick Reply: Ultimate CVH
