Ultimate CVH
..BS Motorsport..
Right, been off the scene for years now but catching the bug again. Ive still got my NMS stage 5 engine in the car but been stood for 5+ years I'd say. I think the block isn't useable, I believe it has a hairline crack on the front. So out of that the steel rods and pistons (standard size) and crank are probably more than fine. The head is a NMS head but again hasn't been used for ages so would need a freshen up, but, its an oddball and has oversized followers which no one does anymore so the only option ive found is newman said they may be able to do a batch of solids oversized when they do the next batch, and in fairness I would probably be using one of their cams in it.
So, ultimate CVH. Whats needed and who is on these nowadays? I don't need people saying go zvh or zetec, im not going down that route. Im sticking CVH and would like to use some of the bits I already have. So, with 320BHP+ in mind, what spec? Keeping in mind it needs to be bombproof near enough. Don't want to be messing about every 500 miles (don't get me wrong, I know in that state of tune it will only be good for 20k miles).
Ben
1900 is essential IMO, going by what I've read about the strength advantages over the 1.6.
Stu Collins is the person to speak too, he's running solid lifters and a custom roller rocker set up to stop it pulling the rocker studs out of the head on boost
And nms the best cvh tuner
For me it would be
Gtx28 with external gate and screamer
Crazycage custom manifolds
Cosworth throttle bodie
All steel bottom end with slipper type rods and pistons
Your nms head with the custom lifters
Roller rocker set up like stu's
Fully balanced
Siemens injectors
Management fitted and mapped by mark sheed
Grs coolers
Genuine ford head gasket!! Best for a cvh
A genuine ford oil pump if you can find one, burton ones are shit!!
Helix 6 paddle, was told they will make to order
Hydraulic clutch set up
Frs mk1 box set up
Maybe dry sump to get around oil pump problems
Nms spec cam or new mans cam specced to suit
I could be here all day with building the ultimate cvh lol
And don't forget the fuel system
For me it would be
Fully balanced
Siemens injectors
Grs coolers
Frs mk1 box set up
post whore
Stephen if my car goes I have some decent Parts that will be up for sale.cosworth management on l6 ecu with coil pack mod.sitech side fed inlet and a crazy cage over the gearbox manifold that is brand new although I had said to gadget if it was any good to him and he is seeing how much it would be to change the flange on it as its for a cvh which would be perfect for you.
Balls Deep!
Things have changed a bit since your CVH was built, NMS do not use CVH blocks for big power builds any more, they are too brittle and prone to cracking these days.
A sleeved Duratec (I think) block is used with custom crank, rods and pistons, then matched with a NMS spec CVH head and cam, then it's just a case of manifolds and turbo.
Obviously things like the fuel system, clutch, gearbox, management, mounts, etc. all need to be considered too, but that goes without saying.
So in your instance nothing you have can be used except the head.
Of course if you do stay true CVH and use an original block that's up to you, but Karl says they do not last long at all and advises against it.
from what i understand the roller rockers are a bit hit and miss
i have looked into these alot and did speak to titan about remaking them
but after speaking to a few people in the know they all said oe is the way to go
karl @nms use to get them made in batches but had a few problems with them so stopped using them
i forget the reason now but they all failed at the same point (he was pushing harder than most with the cvh powerwise)
as for ultimate it would really depend on what you are using the car for imo
..BS Motorsport..
For me it would be
Gtx28 with external gate and screamer sounds good to me
Crazycage custom manifolds that's what I thought
Roller rocker set up like stu's aren't they rarer than rare?
Fully balanced
Siemens injectors
Management fitted and mapped by mark sheed which management
Grs coolers
Frs mk1 box set up
And don't forget the fuel system![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
For me it would be
Fully balanced
Siemens injectors
Grs coolers
Frs mk1 box set up
True but cvh blocks have been proven at 300bho many times so if he wasn't looking for a lot more than that then I would just rebuild what he has
But if he does want to go mental then sell it all and go all out on the new spec and have the best out there
..BS Motorsport..
Nothing other than a toy, not specifically drag but would like to run it if I want, and again not a pure track weapon but in all fairness that's probably where the bulk of use would be. I know going for an all round spec isn't ideal but im not wanting to break any records, just have a shit load of fun in the old girl.
Cossie is great in the hands of msd and nms, but you could have a better running package and more drivability with something like altronic sm4 or vipec with either a gtx or a borg Warner efr type turbo
These things are light years ahead in terms of development compaired to webber and old garrett turbos
..BS Motorsport..
..BS Motorsport..
Totally agree, I think more than power I just want it to be reliable and feel that way. When it ran before on the 5th injector setup etc, it always felt like luck had a lot to do with it
jamsports new head gasket will stop the head lifting
![Name: fiestabits_zpsd1f7018d.jpg
Size: 74.0 KB](https://passionford.com/forum/attachments/general-car-related-discussion/91435d1501528187-ultimate-cvh-fiestabits_zpsd1f7018d.jpg)
![Name: fiestabits069_zps1867bed9.jpg
Size: 94.1 KB](https://passionford.com/forum/attachments/general-car-related-discussion/91436d1501528187-ultimate-cvh-fiestabits069_zps1867bed9.jpg)
![Name: fiestabits068_zpsc11a5c6e.jpg
Size: 44.9 KB](https://passionford.com/forum/attachments/general-car-related-discussion/91437d1501528187-ultimate-cvh-fiestabits068_zpsc11a5c6e.jpg)
![Name: fiestabits070_zps107c04ea.jpg
Size: 84.2 KB](https://passionford.com/forum/attachments/general-car-related-discussion/91438d1501528187-ultimate-cvh-fiestabits070_zps107c04ea.jpg)
oil pump problems taken care of with zetec dry sump kit with block modded
only thing i would change is to a steel crank but has any 1 eva snapped a crank
block is the weak point mine twisted last rear across the mains
me personally love my zetec turbo, as most will know i swore by all my old cvh's but i wouldnt go back, when you can build a 300bhp zetec turbo for around a grand
i know a guy who sells steel rods for £300 with arps and glyco bearings
c20let pistons £100
devil developments valve springs £150
then that leaves you £450 for frs gaskets, rebore to 86mm, rings, water pump and timing belt kit and it will see off a 300bhp cvh with ease due to drivability and the way it delivers its power
and to get a cvh tall block to except 300bhp you need about 2.5k
you could do the zetec even cheaper if you follow karlos and use a st170 bottom end and black top head with 1.8mm frs head gasket
Balls Deep!
I can't remember mate, it was a while ago I spoke to Karl about it, but basically it's a 6k build or there about's with all the custom parts so not cheap, but he said that's the only way he would build big power CVH's these days as the blocks are just too unreliable now.
Balls Deep!
I remember Christian and Karl talking about going M12 bolts but worried about the block taking it.
