Ultimate CVH
Old 23-06-2013, 10:37 PM
  #41
rsmark86
rsmark86's Avatar
Originally Posted by StephenC
Suppose a zvh could be an option?
they are the two worse bits of each engine
zetec head makes so much difference and its cheaper to build a full blown zetec
and theres so much off the shelf parts that its an easy conversion, rouse do water hose kits for the conversion off the shelf.
im using a cvh manifold and a blacktop/frs inlet, dont bother with adaptor plates as its a couple of hours work to drill and tap the head to fit the cvh exhaust manifold.
both of these will piss 300bhp and i got a complete blacktop inlet including throttle bodie and fuel rail for £35 and the fiesta rs turbo fuel pressure reg bolts straight too it, so the only custom bit needed to fit is a charge pipe, and the best bit of this inlet is you can close your bonnet without stupid spacers
use a 1.8 zetec sump and pickup and water pump and your downpipe will fit straight up as will the turbo you have sat there.
for the thermostat housing there is a kit on ebay that makes the cvh thermostat bolt to the zetec head for £25 so you can have the fans running off you exsisting car loom and not on a switch
get a zetec alternator pulley and that bolts to your alternator too
the best bit is theres so many bits you can re-use
Old 23-06-2013, 10:46 PM
  #42
rsmark86
rsmark86's Avatar
apart from the engine the main bits you will need to change are
drill your flywheel to bolt to the zetec crank
breather and oil return ect
bottom water hose as the zetec water pump has a different outlet size
need pulley for alternator and belt
make a charge pipe
thermostat housing conversion plate
fuel pipes in engine bay
and pretty much everything else will fit upto this with what you have.
and if you are efi or cossie management then use what you already have and it will work unless you are on cossie management then you need a new cam sensor bracket
and with aftermarket management theres endless choices, use a efi loom and sensors and fit a boost monkeys ofam ecu with the upgrades?
Old 24-06-2013, 05:52 AM
  #43
stuart collins
stuart collins's Avatar
Originally Posted by Karlos G
How does the gasket stop the head lifting?
I remember Christian and Karl talking about going M12 bolts but worried about the block taking it.
it wont stop it lifting but will stop it blowing if it does as the rings a machined in to the top of the block all the gasket does is stop oil and water mix now , rated to 3bar
Old 24-06-2013, 05:59 AM
  #44
rsmark86
rsmark86's Avatar
so its like the old cossie route of wire ringing the block and useing a group a gasket?
this route worked fine on one of my old cossies at 30psi boost
Old 24-06-2013, 06:02 AM
  #45
rsmark86
rsmark86's Avatar
I can't remember mate, it was a while ago I spoke to Karl about it, but basically it's a 6k build or there about's with all the custom parts so not cheap, but he said that's the only way he would build big power CVH's these days as the blocks are just too unreliable now.
6k ? i would rather use a focus rs tall block and spend the money else where and getting the most drivability possible and having a bullet proof trainsmission and a solid 350bhp
Old 24-06-2013, 06:10 AM
  #46
stuart collins
no , if is was wire ringing the block i would have said that
Old 24-06-2013, 06:48 AM
  #47
gus
gus's Avatar
Blocks machined?
Old 24-06-2013, 07:06 AM
  #48
QplateRST!
1/4 mile beasty!!!!
QplateRST!'s Avatar
I love a good cvh turbo but if your chasing numbers and power why bother with a cvh when a zetec turbo will do a reliable 400hp for half the price
Not saying that cvh,s are shit look at stu's it's a full on monster and puts the times in down the drag strip
Old 24-06-2013, 07:56 AM
  #49
StephenC
..BS Motorsport..
StephenC's Avatar
Don't know what to do now! As said earlier, whatever I do it'll need new fuel system and wiring/management so really any engine is an option as long as it fits. Truth be told I fancied and evo engine with evo box converted to FWD, circa 400-450bhp and would take abuse all day long. Then I thought, well, I've got this old nms engine doing nothing, let's salvage some of that. The smart money looks like a zetec turbo, and my only reason not to as sad as it sounds, is I don't like the look of them!!!!!
Old 24-06-2013, 11:55 AM
  #50
StephenC
..BS Motorsport..
StephenC's Avatar
So which zetec turbos are we looking at for inspiration, off the top of my head there's Luca fiesta?
Old 24-06-2013, 12:08 PM
  #51
QplateRST!
1/4 mile beasty!!!!
QplateRST!'s Avatar
Depends what you want to use it for ie drag, track or road
what you budget is and how reliable you want it
Old 24-06-2013, 12:10 PM
  #52
Ben26
Ben26's Avatar
That fat little bold scouse bloke who has the Mk1 focus RS' 500+ bhp
Old 24-06-2013, 12:13 PM
  #53
PF Ben
PF Ben's Avatar
HAS to be a Zetec turbo these days, have a chat with Devil Developments top bunch and will get you the power you're after no worries!!
For me, only people who are racing to regulations have a reason to stick with a CVH turbo... and only retards would want one for big power on the road*
*Stu nothwithstanding! He's not a retard he's a top bloke met him whilst featuring his car many many years ago!
Old 24-06-2013, 01:14 PM
  #54
StephenC
..BS Motorsport..
StephenC's Avatar
Want it for drag, track and road really. Budget I'd say 6-10k and want it very reliable. Really don't want it breaking every time I take it out.
Old 24-06-2013, 01:28 PM
  #55
QplateRST!
1/4 mile beasty!!!!
QplateRST!'s Avatar
Buy a mk1 focus rs tune it job done
Old 24-06-2013, 01:32 PM
  #56
rsmark86
rsmark86's Avatar
There's people fitting Honda k20 vtecs, fully forged with vipec v88 and efr turbos in fords these days
And they fit, 9500/10000 revs, 500bhp on a lowish boost engine, the head on a k20 will flow good for 700bhp with just some up rated cams, so if I had the money I would look at a different tyre of engine other than a ford
Street racers fitted a Evo engine running a mk2 frs gearbox (fwd) and it makes 609bhp in a pug 205
6k for a cvh, I would rather look else where
Old 24-06-2013, 01:44 PM
  #57
rsmark86
rsmark86's Avatar
There's a guy running in time attack with a black s1 running a full focus rs mk1 running gear on aftermarket ecu and around 300bhp and wins everything in his class racing things like a 550bhp astra vxr?
To get 300bhp out of a focus rs engine all that's needed it
Forge actuator
Up rated exhaust manifold
Decent intercooler
Free flowing exhaust system turbo back
Induction kit
Remapp, in your case management
Standard box, clutch, ancillarys are all at there best still at this "mild" state of tune
And to fit the engine it's the same as a zetec turbo, but fit the frs box and you will need shafts and mount kit of crazycage on here
Old 24-06-2013, 01:56 PM
  #58
Brendan
struggling with reality
Brendan's Avatar
If you have oil problems have a look at an Accu sump!
Collins uses one in there focus! They very effectivly stop oil starvation on a standard sump!
I use one in my CVH happy to provide pics if needed!
http://www.accusump.com
Old 24-06-2013, 02:05 PM
  #59
Canada1
Canada1's Avatar
I was under the impression that for high power builds the CGI Zetec block was used. These are no longer being manufactured, and are expensive if you can find one.
Easy power increase is extra displacement 2.0 instead of 1.6.
But you need a well prepared cylinder head, inlet, and exhaust working together to supply enough air/fuel for a 2.0.
It is not the most cost effective to build a big power CVH - but I love them!
The tall 1.9 block is certainly not stronger than the standard 1.6. It just provides larger displacement and is better than an overbored 1.6.
Old 24-06-2013, 02:28 PM
  #60
rsmark86
rsmark86's Avatar
Tall blocks are no better than a cvh, the zetec bottom end is not the best
It's the zetec head that makes all the difference
And I've not heard of one frs having oil pump problems, especially at 300bhp so if I was building one I would save myself hassle and cash and buy a frs tall block, then fit a tubular manifold and a johnfrs hybrid and new injectors and have a punchy 330bhp
Old 24-06-2013, 04:07 PM
  #61
gus
gus's Avatar
I know what you mean there
For some reason I'm stuck on my cvh
I love it
Old 24-06-2013, 04:24 PM
  #62
rsmark86
rsmark86's Avatar
Duratec turbo?
Could run a nice cosworth or mountune inlet and a custom manifold and they make serious hp
Mondeo mtx bolts up, and I have heard that a mk2 frs 6speed does ( but will need to check) and the frs mk2 box has been in 600bhp cars without issues so far
Or be different and fit a mk2 frs engine and box, that would be awesome
Old 24-06-2013, 04:28 PM
  #63
StephenC
..BS Motorsport..
StephenC's Avatar
Too many options. I think turbod Valencia and call it a day
Old 24-06-2013, 04:31 PM
  #64
crazycage
crazycage's Avatar
i'd go for a evo engine . if I could turn the clock back that's what I would of done to mine . got to much money tied up in my zetec to change now
Old 24-06-2013, 04:38 PM
  #65
StephenC
..BS Motorsport..
StephenC's Avatar
I was set on the evo, guy up our way does the gearbox conversion and runs it in that drag FTO at silly power. Would be reliable as fuck too at the power I want.
Old 24-06-2013, 04:40 PM
  #66
gus
gus's Avatar
o thats what i was trying to say
hows the candle sticks coming on???
Old 24-06-2013, 04:50 PM
  #67
crazycage
crazycage's Avatar
there getting there lol im sure im burning the candle at both ends tho.
I have thought about selling off the zetec parts but I don't like the idea of giving in ,might build a evo powered escort later in the year
Old 24-06-2013, 05:03 PM
  #68
rsmark86
rsmark86's Avatar
I have thought about selling off the zetec parts but I don't like the idea of giving in ,might build a evo powered escort latter in the year
Remember to make templates as a few of us may follow lol
Old 24-06-2013, 05:14 PM
  #69
crazycage
crazycage's Avatar
the only problem I can see with it is fitting it to a gearbox the rest isn't any different to fitting a zetec
Old 24-06-2013, 05:24 PM
  #70
Joe91
Joe91's Avatar
It's not a bad thing? I have plenty on people ask what 'power' I'm running and I tell them and they say 'is that a Zetec turbo?' No it's not actually its 1.6cvh, zetecs and zvh's are very common these days for the reasons discussed above but some of us have alot of money in our cvh's and can't let them go! I just prefer to say I have a powerful cvh instead of Zetec or zvh..
As for the O.P. it depends what you want and how much your willing to pay, I'm about to go back up to NMS for mapping my new T34 to 28psi, it will be near the 300bhp mark, any more and it will be unreliable and won't last to long..Karl said he has stopped making big power cvh's now which is fair enough, I'm sure they would still make you one if you wanted it?
Joe
Old 24-06-2013, 05:50 PM
  #71
russ rs
russ rs's Avatar
Had anyone used liners in the cvh block?? As
I have been looking at my options before car is
Ready for engine to go in
Old 24-06-2013, 05:58 PM
  #72
gus
gus's Avatar
i spoke about
i want to build another engine but do something different to the norm
so was chatting about it and sorting a plan
then my work went belly up
so thats as far as it got
Old 24-06-2013, 06:34 PM
  #73
creator
creator's Avatar
gary,rob @ constella has an evo engine in his 205 bolted to a mk1 focus rs box maybe worth having a word if intrested mate.
Old 24-06-2013, 06:44 PM
  #74
russ rs
russ rs's Avatar
i spoke about
I know feeling about work etc car comes last lol.
I got access to liners and measured up its if cam justify
As stu said mite aswell steel crank then
Old 24-06-2013, 07:07 PM
  #75
gus
gus's Avatar
i was thinking big bore short stroke so would of been a custom crank
or maybe the complete oposite
lol
Old 24-06-2013, 07:12 PM
  #76
StephenC
..BS Motorsport..
StephenC's Avatar
I spoke to Rob about it last year and he said it was a nightmare to do and they wouldnt really be happy doing another as it wouldnt be worth it to them, as in, once theyve sold one it will get copied and sold cheaper. Think he had a lot of welding and machining to the bell housing. My plan was to keep the evo box, convert it to fwd (think its new diff, blanking plate and a few other bits) then use V6 FTO driveshaft inners mated to ford outers (dave mac shafts). BUT, the kit alone to go fwd is 3k which is a bit steep really, im sure you could get a mk1 or mk2 FRS box and get the machining done to that for less.
An EVO engine would also look pretty nice in the series 2 engine bay. Think the first thing to do is measure up to make sure it would fit. Dont suppose anyone has any access or knows of any measurements of a) an EVO block and any ancilliaries on the crank end and b) the various gearbox options and finally c) the space in the mk4 bay before modifying.?
Old 24-06-2013, 07:22 PM
  #77
stuart collins
well ive just fitted a cossie engine and mtx box into a mk4 so a evo engine should go in easy
Old 24-06-2013, 08:01 PM
  #78
russ rs
russ rs's Avatar
Yep go in mk3 fiesta ok
Old 24-06-2013, 08:04 PM
  #79
russ rs
russ rs's Avatar
lol
Highly opinionated subject on the net as usual
Old 24-06-2013, 08:44 PM
  #80
rsmark86
rsmark86's Avatar
what spec you going to the the yb at stu?
Quick Reply: Ultimate CVH
