MK4 fiesta coilover problems
Old May 20, 2013 | 01:05 AM
chriskinsella87's Avatar
chriskinsella87
Default MK4 fiesta coilover problems
Hi all.
I'm really struggling with which type of coilovers to get on my mk 4 fiesta. I'm after eye mounted (not fork mounted).
Considering the mk5 is very similar to the mk4 (and my mk4 is a 99 model) will they not be able to fit the same type of eye mounted coilovers?
All of the packages for the mk4 seem to be far too expensive (£500+) whereas I have found mk5 kits for under £250.
I'm wanting around a 100mm drop and firmer ride for road use
Thanks in advance!
Chris
Old May 20, 2013 | 06:32 AM
bagginsRSturbo's Avatar
bagginsRSturbo
Originally Posted by chriskinsella87
Hi all.
Thanks in advance!
Chris
Hi
The mk4 use afork type where as the mk5 use the eye so the rear beams are different as I have had to change my beam to a mk5 so my suspension would fit
Old May 20, 2013 | 01:25 PM
chriskinsella87
I have eye mounted, or at least I'm pretty sure anyway. And it's on my MK4. Are you saying all mk4s are fork and all mk5s are eye?
Old May 20, 2013 | 01:30 PM
Straight_4_N/a's Avatar
Straight_4_N/a
fiestas 1996 to 1999 are fork
fiestas 1999 to 2002 are eye
if you have a 1999 model you will have to check which you have (ie V reg fiestas used both types)
Old May 20, 2013 | 01:53 PM
chriskinsella87
Right OK. Some of these companies selling coilover kits for mk4s don't seem to mention fork or eye mounted. They just use (JAS/JBS) which I've tried to find out the meaning for, but I'm strugging!
Mine is a T reg 99 model and I'm pretty sure it's eye mounted. I've had a look at the part that connects to the rear beam and there is a single bolt going through.
I found these (by far the cheapest yet) that would fit a mk5. If mine is eye mounted will it not fit mine also?
http://www.lowerks.com/shop-by-car-b...-jh3jd1-01-08/
Thanks for the help as well. Very much appreciated
Old May 20, 2013 | 02:31 PM
Straight_4_N/a
Look at the rear beam and see if the bottom of the shock goes over or in the rear beam. If it goes over it then its fork fitment but if it slots inside the rear beam its an eye fitment.
lmao the mk5 1999 to 2002 anit a mk5 its a mk4 facelift and 90% of companys inc ford say the fiesta 1996 to 2002 is the same car and list them all parts as mk4, So those coil overs are for the 2002+ fiesta so will never fit.
Old May 20, 2013 | 03:03 PM
chriskinsella87
Right OK. I'm very glad you've cleared that up for me as I had no idea. They are very similar other than the front headlights. Am I right in saying JAS and JBS refer to the earlier and later (facelifted) models?
Why the hell is it so expensive to lower them!? My mate lowered his Ibiza sport 110mm (coilovers and labour) for under £250!!!
Old May 21, 2013 | 09:45 PM
charliechoco's Avatar
charliechoco
early mk4's and puma's had fork mount rear beams, late mk4's, late puma's and all mk's had eye mount rear beams
fork mount coilovers will fit all early mk4's and early puma's
eye mount coilovers will fit all late mk4's, late puma's and all mk5's
JoeyBoyden
Jan 4, 2024 02:36 PM
A.t.p
Aug 15, 2015 11:37 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
saph in dorset
Aug 14, 2015 10:10 AM
Sjieter
Aug 5, 2015 09:47 PM
