2007 transit key fob
esc cossie
i want 2 change the blue bit of key cause i have broke the keyring holder but it looks like a sealed unit u can buy just the blue bit on ebay or do i need 2 get a whole new key many thanks 4 any help
Yes they do split with a knife and you can buy the blanks off ebay.
However if it goes the same as my changeover did, you'll end up at Ford paying £135 for a new programmed key.
You can't program the blue keys in the van.
st170 breaking
Split it and buy a new eBay case
I did with the tranny I just sold but be carefull how you split it as you don't want to lever against the pcb
Mine didn't work with the case broken but worked perfect once swapped
st170 breaking
And you should glue it together but I used tape so it can be swapped again if needed
Mine was 3 quid posted from the cheapest guy
They all seem to be the same and some were £50!!!!!
st170 breaking
The battery can be changed but theyvare soldered so a lityle fiddly and you can charge a flat key in another tranny by starting with the vans fob loose then swap them so the flat fob is layed in the key to charge for a little while
You can also buy a 2nd hand fob then home code it for rcl but the immob side is trickier but I think they can be cloned by a key guy
st170 breaking
I had no problem
It's not the usual glass tube which will break it was a black block
Mine had damage to the buttons and ring loop so I split it at the button splits until everything cane out and into the new casing
Easy as pie
I wish I took pics but I didnt
Easy as pie
st170 breaking
I did it
With the amount of people selling the casings on eBay it has to be possible
There are differences to the black housings but I expect you could insert into one if those with some trimming
esc cossie
Thanks guys split it open and changed it and stuck the new 1 wiv super glue works perfect bit of a Shit splitting old just have 2 b careful sharp knife works a treat cheers
Location: in a nice, small & quiet village near Huddersfield
NC53
13-09-2015 03:05 PM
