Citroen question - Adblue?
A friend has got a C4 grand picasso, has been having a few problems with it. The main dealer have said it is low on additive, blue liquid, for emmissions.
Would this be the same as Adblue? And would sticking some Adblue in cause any problems, or would it have to be the stuff Citroen are pushing them to use. The reason for asking is the price, Adblue is a lot cheaper than Citroens brand of additive.
Cheers,
Cheers,
It won't be adblue.
Adblue is used at about 5-7% to fuel.
It will be the additive for DPF regen if that's the system Citroen use.
If it was adblue he would know and as far as I am aware cars are not using it.
Spelling Club King!
It will probably be the glorified pig piss for the DPF. Will be a LOT cheaper to buy it anywhere other than the main dealer...
http://www.eurocarparts.com/ecp/p/ca...0302&0&cc5_871
3dr Cosworth owner
What he needs is something called eolys fluid. It has a seperate tank and injects some into fuel system every time you open the fuel flap to fill up with diesel. It costs about 30 - 35 quid a litre. usually holds about 5 litres but when you have filled it up the ecu needs to be told its been filled so needs plugging in to some obd software. ive just gone throught this with my 407 hdi
Resident Wrestling Legend
My mate new merc has an Adblue cap under the diseasal filler flap
So cars do use them
http://www.caranddriver.com/photos-1...s-photo-411983
So cars do use them
