Anyone that has done the BOA conversion with manual box HELP please!!
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I'm rather stuck I've fitted mt75 hybrid gearbox (manual rwd)to my engine all ok however when I went to fit the gearshift cradle I realised a black bracket is missing that the cradle sits on which I will acquire this week but how do I connect the gearstick part to the gear selector on the gearbox as the gear stick piece is different to the mt75 4x4 cradle and connector I had.
Use the 4wd rod and it will connect to the selector rod on the gearbox. There is a clip and it all goes together. And it will be stronger and tighter then the flat plate version
Is that what you did bud, I did think about this but wasn't sure if the rod was longer shorter. I know what you mean it unbolts under gearstick surround on both.
Sure did bud, its so much stronger than the flat plate version
