misfire fault on 2 litre pinto
insane
hi wondering if anyone has got any advice got a misfire fault on 2 litre pinto changed plugs dizzy rota arm running on bike carburettors stripped them no difference checked coil got electronic ignition was wondering if thats the cause working off manual petrol pump with inline fuel regulator could it be the module any help would be appreciated cheers
all gaskets and jets ,seals in carbs .. i had simmiler problem but mine is on a 32/36 carb and it turned out the be the power valve gasket was split (and it was brand new about 6 months before hand ) so changed that and its been fine ever since , sounds like carb problem to me as you have changed all the other problem areas
insane
new cam about six months ago car only done a few hundred miles since rebuild been set up with carbs for over a year no probs completely stuck as is the garage
as i said i dont know a great deal about the bike carb pinto set up , do you have to re jet the carbs ? and are you running the same regulator the bike would run ? and dose the misfire happen when you just rev the engine ie standing rev not driving ? and i am guessing its new fuel?
insane
still no joy since changed module coil had carbs checked and professionally cleaned compresion and spark good petrol getting to carbs ok misfires bad then dies timing is ok real mystery well stuck anyone had these probs![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Jesus!! Thinks its time it went to a specialist. Sounds like a nightmare.
Have you tried points and condenser ,is it a new dizzy as these crack
It could be that the dizzy is to advanced or not enough have you tried turning it by undoing the 13 mm bolt the bracket and turn the whole thing !!!!
insane
electronic dizzy ,yeah m8 advanced timing still no good bran new dizzy cap ,taken it to two garages ,just guessing what it might be pissing in the wind lol
It does all point to blowen head gasket
Wot was the compression on each cylinder should be around 125 bar of pressure per cylinder
Have you changed all ht leads !!!
Hi
Got a reply on the other site a go on
Top
Re: pinto 2.0
by darkbluevanman ť Sun Apr 21, 2013 10:53 pm
Are you sure it's a misfire??.... could be an overly rich fuelling!... my pinto is on bike carbs now and it's super smooth apart from a little rich low down to kill a flat spot, if I idle to long I get a stumble as the richness chokes it a bit... have you changed anything in the carbs???
I'm on manual pump with fuel reg too.
Illegitimi non carborundum...
darkbluevanman
Transit Extremist
Top
Re: pinto 2.0
darkbluevanman
Transit Extremist
insane
not changed anything in the carbs mechanical fuel pump ok, got carbs off now gonna get 38 dgas set up for the pinto ,decided to go for new rather than mess about with second hand stuff take it from there
![Talking](https://passionford.com/forum/images/icons/icon10.gif)
Hi go it some more info
The problem is the carbs
Most likely the carbs making it run pony.... stripdown in the least.... all needles must have the circlip on the bottom slot, mains should be around 160/170 depending on what carbs they are, start with mixtures 2.5 or 3 turns out from lightly seated.... assuming there is no airbox as such... be careful not to trap the diaphrams when fitting the carbs tops back on and watch out for any little o-rings too, don't let the carbs faze you, imagine they are 1 carb at a time, they will need a balnce too, this can make they run gogga, this can be done by eye with the carbs off, but easier with gauges... if unsure ASK... I've stripped cleaned and setup loads of bike carbs (on bikes).
insane
cheers for info m8 the carbs were stripped and cleaned good diaphrams no clips missing on ebay at the mo getting 38 dgas at the weekend keep you posted m8
insane
o very nice
on a full race set up they are around 200bhp (on 48s or 50s), if 40s or 45s 180bhp ish
sound the dogs dangles
just out of intrest what bhp is seen with the bike carbs compared to the twin webbers?
insane
dont really know to be honest never had her dynod with bike carbs will probably have to pay a visit to the rolling road let you know what power its making
insane
just put power spark dizzy on electric fuel pump filter and regulator on just need carbs know unfortunately cant make ford show at santa pod was asked if i wanted to put it on rally stand gutted ,maybe next year
chowfornow
14
05-01-2019 09:01 PM
