Ford Puma key Fob
Ford Puma key Fob
Hi everybody, I have a problem with my key fob. I opened it to replace the batteries and something fell out of it which is about 25mm long, maybe 2 to 3mm thick made of glass and has a twisted copper wire in it plus some more electronic "stuff". Now i have replaced the batteries but i don't know where to stick that little glass part. If i put it in the only place that looks as if it should go and close the fob, the key rattles when i shake it (which wasn't doing before!!!!) Apart from that the fob doesn't open the doors now and i have to do it manually.
I would be very grateful for any kind of help
Dino
Dino
st170 breaking
It points toward the same direction as the key blade and is usually inside a rubber gromit or in the moulding
Don't break it that's the immobiliser chip and you are ducked with out it
Daisychain
22-08-2015 08:12 PM
borboyous
22-08-2015 11:17 AM
