Abs light on transit swb 2.0 di
Anyone shed some light on this we have a solus which won't connect to it so I checked it all manually, all 4 sensors are showing resistance around the 1500/1600 ohm mark and it changes when the wheel is spun, there all showing a 0.14-0.15v pulse when attached, all the fuses are good, the only 2 things I ain't check are the brake switch and the module, I know the light is controlled by the module so it could be an issue with the board inside,
Has anyone had an issue like this before
