comp pressure
Old Mar 26, 2013 | 07:55 PM
2Litre's Avatar
2Litre
Default comp pressure
According to ford spec's @ 8.1 cr (as per manual) conpression tests read as nornmal @8.5 bar @8:1Comp ratio
The following are my results-
1-130.5 psi
2-130.5psi
3-130.5psi
4-130.5ps
I believe my Cr is 7.6:1 but the head has been skimed, is there a linear progression? ie -
7.2:1(ratio) =110PSI (Compression)
7.4:1=120Psi(compression)
7.6:1=130Psi(compression)
7.8:1=140PSI(COMP)
And so on and so forth..............
Thanks for you time.y
My Best , Tim.
it makes sense that
Old Mar 26, 2013 | 08:00 PM
the_frozen_one's Avatar
the_frozen_one
They're closer to 9:1
1 bar is 14.7 psi, call it 15 cos it's simple.
130 divide by 15 is 8.6, plus a little for the missing 0.3 and it's between 8.7 and 8.9
Old Mar 26, 2013 | 08:20 PM
Rs1's Avatar
Rs1
Compression and compression ratio are two different aspects.
There will be a trend/correlation providing you only ever changed the ratio aspect. get a bit more complicated when you bring in valve timming.....which has massive affect on compression.
Old Mar 26, 2013 | 08:24 PM
the_frozen_one
As does boost and charge temp in cylinder increase. But these are statics. As quoted in manuals and as tested with a spark plug replacement pressure gauge. 99% of passionford won't know their dynamic cr, 25% probably won't know what one is
Old Mar 26, 2013 | 08:28 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Did you measure the bore/stroke volume and the volume of the combustion chamber at tdc as that's the best way to get a true compression ratio
Old Mar 26, 2013 | 08:31 PM
gingerturbo
^^^ true this, main reason why a lot have issues
the_frozen_one
I'm willing to bet he doesn't have a 12 inch pin mag block, or a calibrated burette, any cc fluid or a cc plate.
Old Mar 26, 2013 | 08:35 PM
gingerturbo
To a lot of people you just spoke foreign, when you test measure yours do you use a dti gauge to get true tdc as the piston floats over or just go with the notch marks
Old Mar 26, 2013 | 08:40 PM
the_frozen_one
Glad someone understands :-D
True TDC with the dti. Rechecked for each piston ( don't assume firing pairs are equal) grease around the top inch of the cylinder to seal the rings on the way up, scrape excess grease from the piston/bore clearance with a scrap feeler blade and away you go
Old Mar 26, 2013 | 08:47 PM
gingerturbo
Snap. My dti is probily the most used engineering tool I own I think, other than feelers and a vernier
yatta
May 21, 2016 10:31 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
Dubs44
Sep 19, 2015 06:31 AM
