2.4transit lethargic to start cold but perfect after
st170 breaking
Hello peeps
My 2.4 red transit is lethargic to start from cold 2007 (same glows as a 2006? I see no 07 for sale)
After starting its fine for hours until stone cold again
It turns for aaages enough to flat the battery then after some coughing and diesel smoke it runs as well as the brand new ones we just had delivered (yep rattly until warm lol)
I'm thinking glow plugs but is that likely or is here perhaps a relay or similar that could be worth a try
I can glow it several times and it makes no difference
I'm unsure if a little throttle helps it or hinders it when turning over too
Many thanks for any help
Would easy start help diagnose heater plugs? Cheers again
st170 breaking
st170 breaking
Do the free checks first. first check if you have 12v to the glow plug rail, then disconnect the rail and check the resistance from the + side of each glow plug to earth. each should give a reading of a few ohms but fairly equal across all 4.
if you dont have 12v then look at the fuse/relay,
if you have power and no resistance on some/all of the plugs change the plugs,
if all the plugs measure ok, then look at the pump head as said above.
Does it only do it on first start up in the morning or when it's been left for a while and then fine afterwards?
If so, could possibly be timing chain tensioner going weak,this puts the pump timing out slightly on initial cranking and then they're fine when the tensioner has filled with oil. Unusual on that age transit but not impossible, more common on 2005, 2006 Transits.
Hi, had the same on a few transits i have had, there is a fuseable link that comes off the positive battery trrminal that powers the glow plug circuit, this can crap itself and not supply power to the glow plugs! It is normally taped into the loom up to 6 inches from the terminal, have a look at that, if its gone ,get a big 40 amp or so maxi fuse, some big spade connectors and put it in, always worked for me ! cheers,
st170 breaking
Is that at the battery or the jump point? I've looked at the engine and have found the glowplugs
I see the relay I'd grey and looks good but I have no second person to try things while the key is being turned but ill get the wife out there tomorrow
And other info gratefully received
It's common rail the glow plugs are there mainly for emissions control! Should start fine at these temps first thing! As said timing chain is very common I got mine to do as its a pig to start when cold in morning then is fine all day.
st170 breaking
Its happening when in run and very cold I could leave it upto around 4 hours before it becomes an issue again
Can the chain tensioner be done with the head on? Was looking to do the plugs but read a lot of problems with them snapping or wreaking the threads
I just want to sell it
st170 breaking
Trouble is doing everything will cost a bundle
Ill check there is power to them then its time to work along a list I guess
The pump head under the bonnet with the yellow button does something when I press it but only once as then it seems to set ??
So far the possibilities are fuel lines, timing, pump head,
Any way to remove any of those options with any checking?
Another thing to consider is doing a leak off test of the injectors, if you have one that is on the way out and causing the fuel rail pressure to be low it would cause it to be difficult to start, although I'd expect it to be like that when it's hot or cold tbh.
Have you got access to a fault code reader/diagnostic machine? If you have, see if there are any pump timing related codes stored, it could be a lot of things, the last thing you want to do is throw loads of money at it and see no improvement
slightly off topic but my 06 plate focus tdci has exactly the same starting problems the op has describe so interested to see what the problem is.
st170 breaking
Found a bad connection where the glow feed goes to a terminal and the other side is a nut and eyelet
Obviously the nut then decided to fuck off into a parallel universe (any idea on size?) and the eyelet is rusted thru but it is getting a current when the ignition is switched on
Cycle the plugs 4-5 times to rule them out either way? Switch on, wait for light to go out, switch off and repeat. After 4 or 5 goes even knackered plugs should be hot enough. If its better that way then the plugs are gone.
Don't listen to all this they don't need plugs, it's just emissions crap, diesels need glow plugs to start easy. End of.
st170 breaking
Tomorrow I was going to give it a 30 second blast with a jump lead from the jump point to the plug power rail then fire her up and see what happens
But a chap was next door who is a bit of diesel expert who went thru it with his meters and all was good there after but it wasn't cold once we tampered with it
No they don't, some diesel engines start first time without glow plugs in any weather. I'm an access engineer so work with diesel engines all day, every day and most start absolutely fine with no glow.
My tddi diesel mondeo starts just the same with no glow at all, only when it is very cold (sub 0deg) do I let the glow plugs warm first as it does take a few extra turns of the key to get it started. The cylinder head temperature switch takes its reading so knows how long to cycle the plugs for, when the engine is above freezing temperatures the glow light on the dash comes on and goes out within a second or two, when it is cold it stays on for 5-6 seconds.
It is a lot to do with emissions, some cars have the glow plugs come on when on cold idle to help get a better combustion, thus better emissions.
Not entirely sane
Some Diesel cars cycle the glow plugs when you first open the driver's door (triggered from the courtesy light switch) This way, the glow cycle will be shorter or non existent when you go to start it. My 2000 Seat Cordoba did it so I expect most modern Diesels do. This is probably why RichieST says they start fine without. I've seem many Diesel engines with shot glow plugs being cranked forever before they'll start and then belching white smoke until it warms up enough to burn the fuel properly.
In cold climate cells we have to run block heaters if we don't have functional glowplugs.
st170 breaking
From my observations the glow light on the dash bares no resemblance to how long the plugs actually heat for too
Same as old escorts the lamp may work but means nowt to the plugs I've even seen petrol conversions where the glow lamp still lights lol
