What am i doing wrong?? New Turbo....
Finally ready to start up the beast since fitting my new T34. I've been told to "bleed" the turbo oil feed pipe until i see fresh oil. But when i crank it over.... nothing! Only a few drips when the pipe is angled down to the floor but hardly anything! I was expecting a constant flow??
Any ideas?
Dan
Any ideas?
Dan
just finding my feet
ya got the coil off and ya using the return to the sump aint ya , you have connected the oil feed from the rear of the block too havent ya
if so then just crank and ya should get it feed though when ya cranking the car,
finally ya deffo aint got a block in the feed line either have ya
I've disconnected the coil lead from the dizzy and cranked it over for a good 30 seconds 2 or 3 times but nothing is coming out. Only a few drips when i place the oil feed below on the floor (so gravity is pushing the oil out). I haven't removed the pipe at all from the block.
As for a blockage.... dunno, hard to tell through stainless steel braiding
take the pipe off and test to see if its blocked or attach some pipe to the back of th block to test the flow and see
as it could even be a block in the back of the block ( doubt it though )
take off the oil feed before the turbo first and with a cup test for the feed, if it comes out then attach to turbo ( should be done this way anyway i was told, so if ya already doing that then test the back of the block with a new pipe
Originally Posted by * Rudey *
im in nottingham and have 1 with inline filter you could have that and send me new 1?
Steve - Will do. but maybe next weekend now
As spiky said , a 6mm socket on the oil pump drive and a speed ratchet or a drill will get the oil up much quicker and wont ruin your battery ! Its not unusual for the oil pumps to go dry if the engine is new or been standing for some time .
Dan
Just got home,
My turbo is off the car so your welcome to pop over and borrow some bits. the turbo wont be going on for 1 week at the earliest
Just got home,
ok checked the feeder pipe, no blockages... or if there was its been blasted away with compressed air
BUT
Cranking it over and over.... no oil coming out where the feeder pipe connects to the block. Just left the pipe off and craking it for ages.... no oil. Its wet with oil but nothing coming out.
wtf!!!
BUT
wtf!!!
Karls a bit busy at the moment, so dont like to bother him unless its urgent..
where as steve needs a break from his e-bay addiction
Will try what steve suggested next weekend
DavidK
27-09-2015 02:55 PM
