Anyone make GpA M14 wheel studs for std hubs ?
As title , i need some GpA M14 wheels studs but for a std type roadcar drive flange , does anyone make these already ?
they use vw studs for group a ,you will have to drill your drive flange to suit .
http://www.swayaway.com/WheelStudsAndNuts.php
http://www.ultimate-engineering.co.uk/wheelstuds.html
http://www.grayston.biz/wheelnutmenu.htm
http://www.ebay.co.uk/itm/VW-Audi-Wh...item46072b6001
you will also need a threaded sleeve to go over the stud which is 18mm o/d 28mm long if you are fitting genuine group a wheels to get the full benefit of the bigger diameter stud .
or there are these but i have never used them .
http://www.ebay.co.uk/itm/Escort-mk2...item337f8f001e
I re drilled my hubs to suit press fit M14 studs
Unlike group A/wrc which are half shank half thread and use a sleeve that is heated and then slid over the shank
I made up fully threaded sleeves to suit my fully threaded Porsche/vw press fit studs
Here's my sleeves I made on the lathe
![](http://img.photobucket.com/albums/v104/CHICKAROO/MK6%20FIESTA%20JWRC%20COSWORTH%20PROJECT/e645de07.jpg)
Fitted with the M14 wheel studs and my wrc front bells etc
![](http://img.photobucket.com/albums/v104/CHICKAROO/MK6%20FIESTA%20JWRC%20COSWORTH%20PROJECT/6eca3bb1.jpg)
Rears
![](http://img.photobucket.com/albums/v104/CHICKAROO/MK6%20FIESTA%20JWRC%20COSWORTH%20PROJECT/c215b3c5.jpg)
Studs you can buy in a lot of places depending on length needed,
Wheel sleeves can not be bought off the shelf anywhere and have to be custom made, the ones Dewitts sell are not threaded
Rears
I think i remember you making those, did you make any spares,pm me if you like .
did you just drill out the flange to a hole or re-knurl the hole to suit the bigger studs ??
Got mine recently from Torsten in gp4 in Galway ,studs and nuts direct fit to cossie running gpa rims
http://grp4fabrications.com/
Gret guy to deal with,makes all sorts of ford race stuff etc...
bigluke200
14
02-09-2015 10:35 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
