C2 vts problem, sorry not a ford
hi all, the mrs has got a c2 vts and its whistling like a kettle, i belive its an air leak and have check the inlet manifold bolts(the ones i can see/feel) but this has not solved the issue. thought maybe a blocked breather causing a vacume/whistle from the cam cover but i removed the filler cap with engine running and no change so i think that rules that out.
help please ...
C2 forums just say took it back to dealers ...
help please ...
Irregular Poster
The inlets are prone to leaks - alloy or plastic!!! They have a rubber seal between them and the head. Take it off and rub vaseline around the seal. Should sort it. If not, the inlet is cracked somewhere
Ok thanks, was hoping some bright helpful soul would have come across it before. Its a cast inlet. Looks like it is in two parts, the plenum bolted onto the ports with eight 8mm bolts the the ports to the head with what appears to be just four 10mm nuts/studs all on the underside
Irregular Poster
Yeah there is two type of inlet for that engine (TU5JP4S). I briefly had that inlet the time i was gathering bits for my Saxo turbo. If its that cast alloy one, it may have cracked. but pull it apart and make sure the seals aint fucked!
Stu @ M Developments
41
21-08-2015 06:47 AM
