Car battery conditions, what you got?
Old 11-12-2012, 04:09 PM
Fil
ELASTIC BAND
Fil's Avatar
Default Car battery conditions, what you got?
looking for something to stay connected to the cosworths battery whilst its sitting in the garage, pluged into the mains.
Old 11-12-2012, 04:10 PM
dojj
Resident Wrestling Legend
dojj's Avatar
think they are called c-tek
best by miles apparently
my halfords one was good for about 2 years and then it started to not work as it should have done
but the c-tek is a little trickle charger/battery conditioner so it charges when it needs charge and then stops when it don't, if you see what i mean
Old 11-12-2012, 04:13 PM
D-Sport
D-Sport's Avatar
Get a normal battery charger plugged into a timer switch and have it come on for say ten mins a day
Old 11-12-2012, 04:56 PM
Fil
ELASTIC BAND
Fil's Avatar
will take a look, but......
i have a battery charger and a timer switch plug already should have thought of that!
Old 11-12-2012, 05:10 PM
D-Sport
D-Sport's Avatar
That's what I use with the 2 escorts in the garage and swap over the connectors every weekend and sometimes top up the spare battery's I have around the place
Old 11-12-2012, 05:17 PM
STEVEST24
ST by Name and by Nature
STEVEST24's Avatar
I have a ctek, they are great bits of kit, my one does multi stage charging and even came with crocodile clips and/or permanent connectors so you can easily swap between vehicles.
Also, it is so small which has come in handy leaving securely in engine of vehicle outside overnight, no hope doing that with my old box type charger.
Old 11-12-2012, 05:19 PM
KSA-Cossie
KSA-Cossie's Avatar
Got mine from aldi for a tenner, works spot on.
Old 11-12-2012, 05:27 PM
Fil
ELASTIC BAND
Fil's Avatar
will give it a test, tho wonder if it might set the alarm off?
RichieST
RichieST's Avatar
Are the solar ones any good? I've thought about something to keep my battery tip top while it's laid up over the winter but have no power in my garage.
Old 11-12-2012, 05:30 PM
phil_rs
yam yammer
phil_rs's Avatar
C-Tek 3600, job done!
Amazon Amazon
Old 11-12-2012, 05:31 PM
D-Sport
D-Sport's Avatar
Doesn't set off any of the 2 alarms on the escorts
Old 11-12-2012, 05:32 PM
Cosnada
Cosnada's Avatar
Are the C-tek units any good for batteries such as Varley red tops?
Old 11-12-2012, 06:01 PM
AJC
PassionFord Gold Member (Male)
AJC's Avatar
I'm on an Aldi one too
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
I have a 15 pounds halfords one on my saff that dose the same job just as well as my 80 odd pounds c tec one on my motorbike lol get down halfords!
Old 11-12-2012, 07:21 PM
coswurv
coswurv's Avatar
Me to, quality bit of kit for the money, think i got mine off scouse.
Old 11-12-2012, 07:53 PM
st220kyle
st220kyle's Avatar
how do these work then, they just keep the battery power topped up?
also while on subject, why in a basic/standard charger manual would they say you have to dissconnect battery from car before charging?
Old 11-12-2012, 08:40 PM
Mike1
Mike1's Avatar
I have a CSI Airflow ( the same people that do the Carcoons ) one that I bought in 99. It's been great. My last battery lasted from before 1999( not sure how long it had been on car already ) to 2010 ( the bad winter ), so somewhere over 11 years which seems a good life for a battery - I forgot to connect it up after a drive on a very cold day and the car sat like that for about 3 weeks in the -18 temps we had. I think the inactivity killed that battery but if it had been left on charge it would still be fine. Who knows though?
Anyway, I think it was about £30 back in 99 so I'm sure it has saved me the cost of a battery over the years
Old 11-12-2012, 11:06 PM
slammedorion
slammedorion's Avatar
I've got one of these on the Orion.
Look at this on eBay:
Save A Battery All-In-One Charger/Maintainer/Tester/Conditioner 12 volt
http://bit.ly/TSXNon
RsS2daz
14-08-2015 05:26 AM
track.focus'd
12-08-2015 05:53 PM
tankybaby66
09-08-2015 07:13 AM
xr_craig
07-08-2015 06:00 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Car battery conditions, what you got?
