Headgasket sealer ..anygood??
hello all just wondering if anyone has used any head gasket sealer and if it works or just a load of crap, my local motor factor has some in and says if it doesn't work the manufacturer gives you 100% money back guarantee
thanks
Andy
thanks
Andy
Bodger of Blackburn
if it doesn't work and sealer falls into the engine and scores the bores will they pay out for that too?
if so, give it a go.
otherwise, skim and a fresh gasket.
it seems all too good to be true and bear in mind if it doesn't work you have to do all the work again.
I work for a motor factors in London and there's a product called steel seal does what your after cost is about Ł35 a bottle but many of my customers have bought it and yes 100% pos feedback it's still only a temp fix in my opinion but never had a cust back to say its sh*t or it failed and they needed to job properly hope this helps
Bodge fix and who'd want to rely on their vehicle to carry themselves and their family about with a bodge like a head gasket sealer I'll never know.
But then I guess most people just use it to 'fix' a car then sell it, which is a nice thought.. Not.
Im not the sort of person to stick chemicals into my engine when its not supposed to be there, if its just on a run around i'd give it ago but not on anything important, especially with headgasket problems i'd just change it.
I agree 100% most my customers are general garages and the cars are micras and corsas nothing special but think its for people that need a quick fix due to low funds
car is a 2.2 hdi shitroen !! C5, done 163000 miles uses around 1 litre every 300 miles or so, engine runs perfect and does not overheat stays on half were its always been, found out today its not leaking in the engine its coming out of the expansion tank cap , took cap off today reved the engine as its vv turbo and after a few revs all the coolant is comming out of the top , 100% headgasket.. car worth maybe 600 quid... .. gona just run it for now and try and keep it off boost as much as possible
Ben
Ben
K seal is mint I bought a rover mgzr off eBay with head gasket failure and stuck a bottle in and it's still driving around a year later with it in! Also used it on a customers rad as a temp fix that was 3 months ago!
old bloke by me tried it and it did not work so he went for a refund and the shop said we will give you your refund when you give us a engineers report
The more turbos,more fun!
I used K-Seal in my old volvo 850R when the radiator started leaking on the way to pod, ran it all day on the Friday without any problems, then on the Saturday i blew the gearbox to pieces, related?
Yeah that steel seal stuff is crap, how on earth can they give you a refund anyway,there's clearly an underlying issue?
I tried it on a saxo 1.1, didn't work so new gasket,was fine then no skimming or anything fancy,cars still going.
Good luck if you get the refund though.
lol at all the popl saying just whip the head off and do the gasket, obviously never worked on a c5 hdi before!!!!
If it was my car i would be trying every additive available and if nothing worked putting it on ebay!
Th c5 isn't a car you can "whip" the head off easily!! - The book time is around twenty hours!!!!!
Gadget
Ford Escort RS Cosworth
14-08-2015 07:19 AM
Gadget
13-08-2015 08:19 PM
