mondeo tddi very low on power
got a mondeo tddi and it is like the turbo isnt working,but you can here the turbo when car is reved any idears?
Had this before on TDDi's where there was no coil light flashing or illuminated yet the car was flat and gutless. Swapped the injectors and it was fine again.
I'd have thought a boost leak would bring on the coil light and produce a fault code relating to either inlet manifold pressure or airflow upper threshold exceeded.
no warning light on just very flat, but i can hear turbo when car is reved had pipe off 2nite and turbo spins free?
boost leak can put light on, most likely turbo underboost fault code or boost pressure sensor fault, as above, check all the boost hoses for splits etc.
big floppy donkey dick
seen lack of boost not put lights on and put it on, depending on driving conditions.
id start with EGR if no boost leaks personally
take some live data ideally with a good scanner
Spelling Club King!
I'm talking from personal experience, not what I've read. Where was the leak that caused the fault code, and what code came up?
Shame, I could have sold you a silicone one for a very good price!
If you fitted an OE one they can go again within a year!
I done one with eaxct same symptoms last week. It was the elbow shaped pipe going on to the right hand side of the inlet. The split was on the inside of the elbow. Very hard to spot.
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
