Aftermarket fuel pump loom help with pics (New problem on post 55)
#41
Super Moderator
The fan looms I have seen that paul supplies have an additional wire that is earth switching that can be wired to an over ride switch in the car
Which is a feature owners quite like
It also controls the fans independently and only one comes on at a the initial temperature and the second is activated a few degrees higher and they are then both active at this higher temp
Quite clever I thought
#42
[quote=Stu @ M Developments;6080022]How can it be, if you dont know what it is your trying to buy?
Lol, All customers are told exactly what it is , and even if they forget , they cant be stranded as the plug is standard across the range of sensors , the only issue they may have is the temp rating , not a real issue even if wrong as none go over boiling point so any sensor will be perfect for a " get you home fix " if the shop you are at cant work out the temp by the colour code on the sensor we supply
Again we found this a great advantage as i would bet no motor factors carry the correct sensor ( OE ) for a cosworth , But andrew page and 3 others we tried in our area ALL had our sensor on the shelf due to it being the most common sensor fitted to most cars over 2009 production
#44
Thanks Tony
we are quite chuffed with the looms and our customers love them
I fit themto every car i own now , along with a new pump loom
#46
Are the temperatures correct for a YB though? I've seen some that run the fans to 79 odd degrees when the stat is shut again
Over ride is a good idea indeed, we offer it as an option if the customer asks as its ideal for cool down Laps on track
What I meant by escort cosworth fan switch was that the escos sensor is twin speed and also has a modern shape plug. The sensor for that is still readily available
And Paul I still love you even if you are grumpy
#49
86 and 89 i think James , I will check with the supplier tho , but i know they are above the stat requirments
Im not grumpy , im just from yorkshire
#55
Ok so i need some help, i cant get the fuel pump to prime, i can get it to run permenatly
The wire labeled "1st" in the picture is the one i was told to use but it wont prime
The wire labelled "2nd runs the pump constantly with the ignition on
The 3rd does nothing
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
