Remapping a BMW MS45 ECU?
Does anyone know what software and hardware is needed to edit the fuel and spark tables in a BMW MS45 ECU?
Got a Z4 with an M45B30 engine that's going turbo and would be easier if I didn't have to change management!
I realise a BMW forum might be the better place to ask but with so many tuners on here (Pro's and home tuners) thought someone might know?!
Cheers!
Cheers!
Depends on the chip in your ECU you will need to open it up! Before with a colleague we did a one with a eprom reader and data read out with WinOLS
you need an OBD tool (I've heard good things about MPPS's) that supports your ECU, then a program to find the maps in the code (e.g WinOLS, TunerPro etc...).
It WILL be cheaper and faster for you to a standalone
It WILL be cheaper and faster for you to go to a standalone
You can use tunerpro and hope to find a defenition file. Then you have to tune it which is very difficult if you dont understand how those works. I would recommend going stand alone or spend a lot of hours trying to find out how it works.
Going standalone is my prefered option TBH but on a car that has two ECU's (DME & EWS) with every system CAN BUS controlled is not as easy as you think, even simple things like the air con, electric memory seats, power steering even the radio are all controlled by the ECU so I have no idea what will work if the ECU doesnt see that the car is running? The PAS for example may not work as the ECU will not activate it until it see's the engine running, this could be a simple as a voltage trigger or it may be RPM triggered (CPS signal) who knows?!
If everything worked relatively easily then I would just MS3 it, but I don't want to be left with half my car systems down and the headache of figuring out how to fool the ECU into thinking it's all ok.
Although this may be the way I end up going... I can unplug things one at a time and see what still works in the car!
Pretty sure your question isn't also answered on a bmw forum. I would try these things. I only have an account on the first.
http://www.chiptuners.org/forums/index.php
http://www.ecuedit.com/
http://www.checksumm.com/
i think trying to get the car to start if putting it aftermarket/standalone will be the biggest hurdle mate due to how the secuirty/imobiliser systems work now a days.the cars i work on everyday (not bmws but im sure there the same) even something like the radio/sterio being wronge and it will not let you start the car. Im sure it has been done but never really looked into standalone systems on new cars.I think youd have to somehow use the same wiring so as your getting readings to the oem ecu?
Yea i have no experience, but why wouldn't you try to get into the chip. With help from these forums you will be able too. Once you have the maps your tuning can be done quite easy.
Yea you will need to figure out your complete system. It will be a difficult challenge!
Cheers!
Cheers!
Thanks for your help
Alun
Thanks
There isn't anything plug and play (that i've found anyway), you need to choose your management (I recommend a GEN8 from www.boostmonkeys.co.uk) and then figure out the wiring, basically you can run the GEN8 (or whatever you choose to use) in parallel with the MS45, this means everything like traction control, VANOS, FBW throttle, idle control, etc. all still works as normal but you can then map the fuelling and timing.
