YB fuel rail mount on inlet
What's the difference between a 2 and a 4wd YB cosworth fuel rail? I need a billet fuel rail that fits on this apparently 4x4 rail fittings? Or a pair of fuel rail mounts making to fit my exhisting fuel rail.*
This is the inlet I have to go on,*
![](http://img.photobucket.com/albums/v78/MrCdrift/04AC1650-6B66-483D-BEB6-B1F200991B54-5588-00000D67D8DA50C5.jpg)
I currently have braided lines so won't use a standard ford item
cossie fan (unluckerly)
Save your self a shit load of money and stick to the rail you have! Or if your going aero quip just mod your rail by having the fittings brazed on
I already have a billet rail, already have the braided hoses, fitting from tank tore etc etc
![](http://img.photobucket.com/albums/v78/MrCdrift/D12enginebay022.jpg)
The genesis rail bolts onto plenum cover bolts 1and4, but the Swedish type has no fixing threads just brackets on top for a 4x4 rail fixing hence my question
the top pic looks like a 2wd fuel rail as it just has a pipe coming out the end to connect to the pressure reg
the 4x4 rail has a bolt on fitting at the end for the reg to attach
Be careful with billet rails, some of them put the injectors at a crap angle, allowing fuel to leak past the seals or even letting the injector pop out! Seen a few times with different rails!
It looks like the one on my old 2wd to be honest yes, and 4x4 ones I've seen have a bracket on the front for a reg.
Can anybody recommend a rail that sit square and mounts on the same face as the standard rail? NOT on the back of the trumpets like mine
JK12
33
26-04-2021 12:09 PM
