ZETEC BOOST DROP - help please
could any body help with this problem... my car ran 32 psi it needed mapping so i drove it as it was at 32 psi it was a animal!!Today i changed intercooler to a airtech one and fitted the fans on the outside of it ..had a pipe made and fitted that .. now my problem is this.
i turned the boost down to 15psi.. drove it around it was fine and perfect.. i changed the intercooler and pipes and now it boosts to 15psi like the normal BUT it drops back down and holds 10psi .. so i checked pipes they LOOK fine..so i adjusted the boost up to 18psi ... now its hitting the normal 18 BUT dropping down again to 10psi when boosting hard.. im guessing its loosing air somewhere just cant see or tell where .. can it be the bleed valve ? any help appreciated
actuator? have you a spare one, -31 pref -34 if running the higher boost bypass the bleed valve and run the hose from actuator to turbo, to eliminate the bleed valve.
cheers for comments guys. the turbo is like new its mint. the problem accured after swapping the intercooler does any body have a leak tester the one that could be tested on the car ?
just an update.
swapped the bleed valve over
tightened pipes
tested the actuater
and still had the same problem which mean the intercooler may be loosing air. getting another though so will have it on there this week
tightened pipes
tested the actuater
Under the car...!
pressurise the system and then wipe some diluted fairy liquid on boost pipes. And all joints etc. it will bubble where the leak is. Last tester kit I made was 3" bung with valve in the middle , tyre pump or compressor to pressure the system.
cheers for comments guys.. the mechanice has said the diaphram thing in the actuater must have split etc.. basically have ordered a new forge actuater... and pee vee .. the fans be on mate its wired up to a switch etc so not blocking air .. its a better set up than my old one because the car runs alot cooler tbh
Thing is, if the diaphram has split in the actuator, it usually makes them boost as much as the turbo can. As the air pressure that's supposed to be opening the actuator to control the boost.. Is all leaking it of the hole.
peevee .. im not sure mate but it aint the intercooler,aint the bleed valve, aint the pipes so im hoping its definately the actuater as thats what the mechanic also thinks.. xr2wishy .. time will tell mate.. its a forge actuater with the alen key head on it. so will see if its that when its replaced.. cheers for comments guys
JK12
33
26-04-2021 12:09 PM
Russ Payne
25-09-2015 08:29 PM
Andypandy260
23-09-2015 10:28 PM
