Another failed gated sump causing engine meltdown
Old Aug 4, 2012 | 05:45 PM
  #281
Less.'s Avatar
Less.
having a mid life crisis
Originally Posted by Jay,
Less fuck offf
Okay I will report you to a mod for swearing at me
Plus okay I will ask a sensible quetion what is det? and with that I shall leave
Old Aug 4, 2012 | 06:00 PM
  #282
mechanic28's Avatar
mechanic28
Originally Posted by Less.
Doug I have learnt that I would not let Luke map my sa nav
And did you know that is impossible to do nothing at all,as even when your are doing nothing you are in fact doing something by doing nothing
ah the old double negative thing lol and det is uncontrolled burning of fuel,pinking in a way but when running high boost etc it will lead to ones piston getting rather moist
Old Aug 4, 2012 | 06:02 PM
  #283
Less.'s Avatar
Less.
Thanks Doug so basically an incorrect air and fuel mixture then?
Old Aug 4, 2012 | 06:05 PM
  #284
mechanic28's Avatar
mechanic28
can be or can be caused by incorrect ignition timing
Old Aug 4, 2012 | 06:41 PM
  #285
Moonstone Steve.'s Avatar
Moonstone Steve.
Originally Posted by 750hp escos
Well Steve if it's history stop trying to Sugest the map caused your engine to fail ! When it did not !! .
Not to sure how many times I have said my Ep map fucked my engine but the reason you are still defending it is because you picked a fight with The Wise One (Tony)
Steve
Old Aug 4, 2012 | 06:59 PM
  #286
Rab's Avatar
Rab
Fucking superstar........
Did you know the first couple to be shown in bed together on prime time television were Fred and Wilma Flintstone?
Amazing!
Old Aug 4, 2012 | 07:33 PM
  #287
750hp escos's Avatar
750hp escos
Default .
This is my point to danny IF chips are incrypted and others are crap why go to these lengths to copy or use info off them when you have your own base maps to work from ? If by anychance you got your hands on a chip so for instance someone who did not understand pectel or webber and you tried to copy it then you would inherit a bad file so then you could end up with something as silly as a bad starting car to a blown up one ! so if you have your own that you have used time and time again why bother with another tuners one
He did not ... Steve is mistaken on his comment ! And your completely off now as the whole debate was would that spark angle have caused the Failier on this engine ---- answer NO .. Ps Steve restricting the Amal valve is common .
Old Aug 4, 2012 | 07:35 PM
  #288
750hp escos
Default .
Steve
Well of that is what you said then indeed you were wrong !
Old Aug 4, 2012 | 07:44 PM
  #289
750hp escos
So back on topic but still off topic lol , the argument was the spark angle caused the falier but indeed it did not therefore the map is not to blaim ! Simples Steve !
Old Aug 4, 2012 | 07:48 PM
  #290
Mark Shead's Avatar
Mark Shead
Mistaken here are the figures off the Dyno The boost @ 4k - 0.4 @ 4.5k - 0.65 @ 5k - 1.4. The lambda @ 4k - 0.84 @ 4.5k - 0.82 and @ 5k - 0.8 ... The software is tdr iems .. Steves Msd chip was never modded or tried to as he wanted to keep it .. Yes Msd chips have been modded .. The fact remains with Steves engine cr etc at the spark advance it was set to would not has caused det .
Accelerated power run in shoot mode?.and was all mapping done like that.
Mark
Old Aug 4, 2012 | 07:49 PM
  #291
mechanic28's Avatar
mechanic28
Amazing!
that is a truely amazing fact i thank u kind sir for sharing this with us
Old Aug 4, 2012 | 07:55 PM
  #292
Turbosystems's Avatar
Turbosystems
Super Moderator
So back on topic but still off topic lol , the argument was the spark angle caused the failure but indeed it did therefore the map is to blame ! Simples Steve !
I have corrected your post for you
Old Aug 4, 2012 | 08:09 PM
  #293
750hp escos
Mark
Mark mapping was done using constant load and steady state rpm hold , the power runs we're done in shoot 4f
Old Aug 4, 2012 | 08:13 PM
  #294
750hp escos
Default .
Ahh bless you tony how does it feel to be WRONG ! I love the fact you have had a come back to which I totally respect but still feel it just to slate others when your own record is not with out Failier ! Not a dig just a fact .. If you were not so grumpy we would probably get on very well lol
Old Aug 4, 2012 | 08:17 PM
  #295
Turbosystems
Super Moderator
are you female danny roflol It is not me that is wrong
let me simplify it for you 4000-4500 rpm 2 bar boost 14.25 degrees = det
you asked for stu's opinion and he posted 9 degrees
my trick steve 4i map you stole and decided you were better than me was 8 degrees so you added 6.25 degrees and took out fuel the result being moonstone has a perfect set of 4 matching detted pistons
nobody elses engine that I have mapped has detted only the one you mapped
Old Aug 4, 2012 | 08:31 PM
  #296
flannigan's Avatar
flannigan
Originally Posted by Stu @ M Developments
To be honest, 7.45:1 and 14 degrees at 7000 rpm is about right with 2bar of boost actually, would normally be around 9 in the midrange for that compression and of course it should go up with RPM to the mid teens as the engines VE drops off.
Not sure why you say you need the car to see inj dur though Danny, the ECU decides injector duration and the correct Pectel software tells you precisely what it will be at any given point and air temperature as long as you know how to use it, as Tony clearly does.
Dont know what this "mismot" software ius you use, but it doesnt sound good if you cant tell what the map is going to output to the engine?
Whats this about tweaking my map and it not starting? Thought you had solved that issue we argued about for days when I said you couldnt alter it, only copy it, and you swore blind you could, so I asked for proof and then everyone went quiet and the topic died after you and I spoke on the phone.
Here is the post !
Old Aug 4, 2012 | 08:49 PM
  #297
Turbosystems
Super Moderator
something else for you danny that has just sprung to mind is whilst you adjusted the ignition tables and messed them up, what you also have done is pasted in the fuel table out of your version of my 4i chip you stole that you harp on was so rich.
let me just remind you what you posted before, the engines are different specs and different turbos 4i on a t38 and moonstone on a mighty t4
You have used exactly the same fuel tables of both
this reminds me I best check rams fuel table as this may also be your lean version of my stolen map as he has dropped a valve seat on number 3
Old Aug 4, 2012 | 08:51 PM
  #298
Jay,'s Avatar
Jay,
Sponsor
Right im still none of the wiser here Danny and this topic has more angles than a mafia boss in court lol BUT MY question i think is on topic seeing as everyone is argueing about files and ignition ect ! so im trying to through light on this ! Now you have openly admitted using msd and turbo system files well tried to use msd's stuff and you claim you have your own Data but want to use theres for some reason but claim tony mapped a car incorrectly and say stu's you cant hack ! So why did you bother with any of them and just not waste your own time and use your own files
Old Aug 4, 2012 | 08:52 PM
  #299
Jay,'s Avatar
Jay,
Sponsor
Originally Posted by flannigan
Here is the post !
just my own exsperience ive only used up to 8 degree at 4000rpm starting to boost climb
Old Aug 4, 2012 | 08:56 PM
  #300
750hp escos
Default .
are you for real danny
Oh god tony you are so depressing, you are quoting statistics not actual live dynamics ! That engine did not det !!! If your so insistent put your bottle of booze down go and build Steves engine to the same spec as last time and put the map in and run it with stu present to confirm ! But that said the engine eaven if built the same may behave slightly different !!!! And tony my escort which ran 647hp at 2.3 bar at 8.1 comp at lam 8.2 had 13.7 degrees spark at 4700 to limiter and never fell Appart ! Luke mapped it from engine Dyno to rolling road to track you may like to check out the vid on you tube . Com and search for Danny and si b !!!!! If Luke can't map why did that car last so long and do so well !!!! STOP your witch hunt and carrie on with your comeback ..... Fact is until you have tried you don't no !!!!
Old Aug 4, 2012 | 08:58 PM
  #301
750hp escos
Default .
You need to get a female and stop editing your posts lol
Old Aug 4, 2012 | 08:59 PM
  #302
flannigan's Avatar
flannigan
That's an easy one that I can answer on his behalf he does not have any occasionally he uploads somebody else's map and changes a few things gets lucky nothing goes wrong and the customer is none the wiser !!!
Old Aug 4, 2012 | 09:05 PM
  #303
Jay,'s Avatar
Jay,
Sponsor
if this a reply to my post i cant see a good tuner do that really
Old Aug 4, 2012 | 09:09 PM
  #304
750hp escos
Default .
Oh god leave the debate lol
Old Aug 4, 2012 | 09:26 PM
  #305
opposite lock's Avatar
opposite lock
Thats just below the belt imo 750hp escos no need for it and banter that is not.
Danny as i,m frequent interested reader on here its coming across like your hating not debating. Surely your in no real position to claim you know what your doing and others dont? Correct me if i,m wrong mate as i dont know you. So far everything you,ve argued seems to of been dealt with and replied by people who dont need to prove anything . If they notice something incorrect it is their professionalism that will determine why and hows. I dont see anything or sense any personal negatives toward you only defintive answers which are consistent with other pro,s views on it.
Keep the passion mate but dont burn bridges so to speak your better than that .
Old Aug 4, 2012 | 09:33 PM
  #306
Turbosystems
Super Moderator
danny moonstones engine will disagree with you as it has 4 beautifully detted pistons
we await your diagnosis and detailed explanation
How can you possibly use as defence the ignition table from an engine that has a different bore stroke ratio,a different displacement, different cams, different head porting, different inlet manifold. totally different ecu and a totally different turbo
Old Aug 4, 2012 | 09:40 PM
  #307
flannigan's Avatar
flannigan
I think you'll find I started this thread about a failed sump baffle pmsl
Feel free to start your own thread about mapping !!!!
Old Aug 4, 2012 | 09:43 PM
  #308
flannigan's Avatar
flannigan
Thats because GOOD tuners don't mate !!!
Old Aug 4, 2012 | 09:44 PM
  #309
Turbosystems
Super Moderator
Don't you mean feel free to start you own post about detting
Old Aug 4, 2012 | 10:11 PM
  #310
Rab's Avatar
Rab
A ducks quack doesn't echo, and no one knows why......
Old Aug 4, 2012 | 10:15 PM
  #311
750hp escos
Default .
Tony stop speculating and get building then we. Can test !!! With stu to watch and advise and listen ! . The map did no cause the failed engine please post pictures of said pistons
Old Aug 4, 2012 | 10:18 PM
  #312
saph4be's Avatar
saph4be
Tony stop speculating and get building then we. Can test !!! With stu to watch and advise and listen ! . The map did no cause the failed engine please post pictures of said pistons xxxx
Your so desperate to prove it was ok you build a engine!
  #313
mechanic28's Avatar
mechanic28
really??
a bumble bee can not scientificly fly but yet the bastards do
Old Aug 4, 2012 | 10:20 PM
  #314
Rab's Avatar
Rab
  #315
Turbosystems
Super Moderator
if i posted pics of said pistons you would only deny that they had detonated or that they aren't moonstones pistons
Moonstone has seen his detted pistons as he took them out
I received the engine in boxes
I doubt the owner of the engine would want to use his new engine to test your theories one could argue he has already tested the map and has the empty wallet to prove it
  #316
flannigan's Avatar
flannigan
I regret not having my car mapped with Danny now as I would have melted my pistons long before my sump baffles came off and caused an issue as the pistons are only Ł550 and I have a repair bill for over 2k !!!
Old Aug 4, 2012 | 10:27 PM
  #317
750hp escos
Post the pictures tony
Old Aug 4, 2012 | 10:28 PM
  #318
Turbosystems
Super Moderator
I haven't taken any
Old Aug 4, 2012 | 10:31 PM
  #319
Rab's Avatar
Rab
Double post
Old Aug 4, 2012 | 10:36 PM
  #320
Turbosystems
Super Moderator
moonstone will be displaying the pistons on the PF stand at ford fair
