Another failed gated sump causing engine meltdown
Old Aug 3, 2012 | 09:39 PM
  #201
mechanic28's Avatar
mechanic28
get my car to 500hp and i may agree tony lol
  #202
mechanic28's Avatar
mechanic28
a safe 500 tho please if there is such a thingoh and better mpg then the tight one
Old Aug 3, 2012 | 09:40 PM
  #203
Moonstone Steve.'s Avatar
Moonstone Steve.
He cant if you keep it in the fucking garage
Steve
Old Aug 3, 2012 | 09:44 PM
  #204
mechanic28's Avatar
mechanic28
Steve
oi u be silent i am getting some bits n peices sorted
Old Aug 3, 2012 | 09:48 PM
  #205
Stu @ M Developments's Avatar
PassionFords Creator
Originally Posted by Turbosystems
stu the rpm points I have listed at 14 degrees are not at 7000 rpm top boost line they are at the mid range
hence me saying that is the reason for the detted engine
Shit, sorry, I thought when you typed 45 THOUSAND RPM you meant the rev limiter was set a tad too high and you were being your usual sarcastic self and meaning it was 14 degrees at somewhere over 8000rpm...
Old Aug 3, 2012 | 09:50 PM
  #206
Thats a nice easy oen Tony, fix its problems, call me to find out what its mapped boost was and just reset it then make some tea. Job jobbed, no mapping required.
Mind you, wait till you try and set off up that fucking big hill near yours with that gearbox... Might be better to get someone to tow you with one of your spare landrovers and just give it a slipstream 70mph rolling start... at least that way you can reach 2nd gear!
Old Aug 3, 2012 | 09:55 PM
  #207
mechanic28's Avatar
mechanic28
the first time i drove her was when i picked her up and it was on the mother of hills in wales i did not stall it tho but i did look like a twat with the amount of revs and slipping of the clutch that was going on
Old Aug 3, 2012 | 09:58 PM
  #208
Its a wicked box, but it doesnt half spoil the car unless your willing to change gear at 8000rpm every time you use it. I dont think I could drive it round the welsh mountains though... fuck that! What if a sheep pulls out on you?
Old Aug 3, 2012 | 10:02 PM
  #209
mechanic28's Avatar
mechanic28
i guess if your welsh pull over chat up said sheep by asking if he?she wants a lift then go have some special time where i live in london dont get many chances to get her to 8k lol just get the chance to look a bit of a twat when pulling off
Old Aug 3, 2012 | 10:14 PM
  #210
Moonstone Steve.
i guess if your welsh pull over chat up said sheep by asking if he?she wants a lift then go have some special time where i live in london dont get many chances to get her to 8k lol just get the chance to look a bit of a twat when pulling myself off
Steve
Old Aug 3, 2012 | 10:17 PM
  #211
Eagle's Avatar
Eagle
Super Moderator
Originally Posted by 750hp escos
The actual cr was not known but it was alot lower cr than 4is and the ignition map obviously represents this..
i dont really want to get involved but isn't the ratio important ?
Old Aug 3, 2012 | 10:18 PM
  #212
Chip's Avatar
Chip
*** Sierra RS Custard ***
its important when trying to accurately spec an engine to a particular requirement, but you can map a car very well without knowing what it is exactly
Old Aug 3, 2012 | 10:24 PM
  #213
mechanic28's Avatar
mechanic28
Steve
very good steve i just figured out what u done
Old Aug 3, 2012 | 10:46 PM
  #214
Turbosystems's Avatar
Turbosystems
Super Moderator
well some people can
Old Aug 3, 2012 | 10:47 PM
  #215
Turbosystems
Super Moderator
doug we could pop it on the hub dyno and you can compare penis sizes with the tall one
Old Aug 3, 2012 | 10:50 PM
  #216
Moonstone Steve.
we better get our cars on that hub dyno before Desert viper goes on there and blows the fucker into orbit pmsl
Steve
Old Aug 3, 2012 | 10:53 PM
  #217
mechanic28's Avatar
mechanic28
the tight one does like a good old compare the penis competition lol
Old Aug 3, 2012 | 10:54 PM
  #218
Turbosystems
Super Moderator
no hub dyno for desert viper we are going to smoke a pf approved DD rolling road first
and then get some accurate figures off the hub dyno
Old Aug 3, 2012 | 10:55 PM
  #219
Turbosystems
Super Moderator
His willy has shrunk alot recently since the purchase of his 3 door slug
  #220
flannigan's Avatar
flannigan
The fucker will have so much grunt it will need a wheelie bar fitted on the rear just to stop it flipping on the Dyno lol better start saving for tires I think because you will need a decent set of rubber and a fookin miricale to get the power down in that thing lol
Old Aug 3, 2012 | 10:59 PM
  #221
Turbosystems
Super Moderator
I still have all the speakrs and base boxes out of it that will cure my traction issues
and we have a jay to shove in the boot
Old Aug 3, 2012 | 11:01 PM
  #222
mechanic28's Avatar
mechanic28
i would go as far to say a slug that has had salt poured on him
Old Aug 3, 2012 | 11:03 PM
  #223
flannigan's Avatar
flannigan
And 800lb rear springs to stop the diff exploding off the Tarmac if you actually get grip
  #224
Moonstone Steve.
I have already layed down the gauntlet and said the moonstone turbosystems saph will kick the arse out of desert viper at santa pod, by the time he gets traction i will be parked up and on my third bacon roll lol
Steve
Old Aug 3, 2012 | 11:05 PM
  #225
Turbosystems
Super Moderator
does anyone remember what the actual original topic of this thread was
Old Aug 3, 2012 | 11:06 PM
  #226
flannigan's Avatar
flannigan
That's if he has not killed someone with transmission missiles being fired out of it lol
  #227
Turbosystems
Super Moderator
no intention of doing the quarter mile just the burn outs
Old Aug 3, 2012 | 11:08 PM
  #228
flannigan's Avatar
flannigan
I'm sure it had something to do with a car that had a shit map on it That was done by a clueless muppet
  #229
Moonstone Steve.
It will be a quarter mile burnout
Steve
  #230
Turbosystems
Super Moderator
Steve
I could always make it 4wd using the mighty mt75
Old Aug 3, 2012 | 11:09 PM
  #231
Turbosystems
Super Moderator
Steve
smokkiiiiin
Old Aug 3, 2012 | 11:12 PM
  #232
flannigan's Avatar
flannigan
I would probbly put an electronic speedo on it and the pickup on the front wheel as otherwise you will be showing 170mph all the time lol
Old Aug 3, 2012 | 11:13 PM
  #233
Turbosystems
Super Moderator
if we are struggling to fit twin turbo charges flannigan has suggest one large one would be my best option
Old Aug 3, 2012 | 11:14 PM
  #234
Kevin Sharp's Avatar
Kevin Sharp
so how long before its done then...chop chop
is the danny posting on here the one from enraged performance? i havent been on for a while
Old Aug 3, 2012 | 11:16 PM
  #235
flannigan's Avatar
flannigan
Yes that's it fitted in the boot area that way it will give maximum power and aid grip pmsl !!!
Ps it may require a tt anti surge housing and billet wheel tho lol
Old Aug 3, 2012 | 11:17 PM
  #236
Turbosystems
Super Moderator
there may be a slight problem with your solution
Old Aug 3, 2012 | 11:27 PM
  #237
flannigan's Avatar
flannigan
There is only one thing wrong with that photo where are all the clouds of smoke and two fire trails behind the car ?
Old Aug 3, 2012 | 11:29 PM
  #238
Turbosystems
Super Moderator
it's not actually running or moving jay got in the boot
Old Aug 3, 2012 | 11:48 PM
  #239
Rab's Avatar
Rab
Fucking superstar........
Brilliant!
Old Aug 4, 2012 | 01:07 AM
  #240
Miller 3's Avatar
Miller 3
Man what a read lol
