Locking rear brakes on track Saff.
I seem to be suffering with rear brakes locking on my car under heavy braking on track, which has resulted in me pointing in the wrong direction ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Has anyone else had this issue and fixed it by running standard pads in the rear rather than higher spec pads?
Not sure if my ABS works any more as the light is on half the time.
I had an issue with the rears locking. It turned out to be warped discs.
Took ages to track down cos I wasn't expecting rears to be warped.
I have 335 6 pots on the frot of mine with ds3000 pads, 305mm with 2wd calipers on the back of mine and use pagid rear pads from euro car parts and it is the most balanced it has ever been.
I used to use ds2500's on the back and the rear brakes were really snatch. I got pissed off spending Ł75 on rear pads that never used to work very well.
I have standard cosworth master cylinder and no bias valve. And I don't suffer with any locking up on the rear.
The euro car parts part number is 101590928
Try them out mate
Try them out mate
Thanks Ronnie, I assume the Pagid pads are just std spec road pads, if so great i have just bought a couple of sets of some make i have never heard of
but should balance the car out if its as you describe.
Ł13.50/set for the ones i bought is a lot cheaper than Ł90 for the DS2500
So if they do me a day, i'd be happy.
I used standard pads (ebc etc) in my 4x4 cossie rears and lost all brakes due to rears catching fire and boiling the brake fluid. That was a brown adrenalin moment. I use green stuff now and thinking of going yellow or blue. I also use Castrol SRF now.
this is what happened to me when the rear brakes on my sierra locked up at the start of a race in May
I braked too hard as the evo in front braked earlier than I expected causing the rear to lock up they have been fine since
my spec is
front AP 330 4 pots DS 3000 pads
Rear std Cos 4x4 rear disks with DS2500 pads
steve
Steve, thats exactly what happened to me 3 times on my last trackday at Oulton. (Twice with Sticky in the car
I'll see how the car performs with the 300mm rear with standard road pads, like Ronnie is running.
Your setup is an alternative option, Std 4x4 disks and track pads.
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Mine used to lock up when I had worn rear beam bushes. As if the back used to move around to much and cause the rear end to go light.
Are all of your bushes ok? It's probably just the pads but worth thinking about.
track.focus'd
12-08-2015 05:53 PM
