any race technology experts out there?
on my dash 2 im using 2 race technology sensors and the rest of the info comes from the ecu, the info from the ecus fine but the readings from the sensor jumps around like mad and its unreadable in the software theres something called filtering is it something to do with these settings???
Testing the future
i'm no expert on race technology gear specifically, but am an expert in instrumentation and datalogging.
it could possibly be smoothed with filtering but hard to say without seeing the readings to know what it's doing as it could also be interference.
what is the sensor and how have you cabled it? have you used a screened cable or a twisted pair?
Testing the future
although the readings are jumping around a bit, are they what you would expect to read? if so, looks like introducing some filtering to the inputs will sort it out
What sensors are they? Could it be an earthing issue somewhere on the dash 2 or sensors? I re-earthed my wideband direct to the chassis and it sorted a similar issue with erratic readings on the data logging side.
The Youth.
30-09-2015 09:59 PM
DavidK
27-09-2015 02:55 PM
