Alternators, help me!!!!!!!!!
before i set this piece of crap on fire!!!!!!!!
Since it's been on the road, its done 1000 miles and it on its 4th alternator, can anyone figure this out?!
Basically, when we got it running, the alternator was showing (what i thought) was signs of age, needed to be rev'd to about 3k before it started charging, so i ordered a recon one from local parts people, turned up, put it on, fine, for a day or 2, then that needed to be rev'd to 4k before it started to work, so they replaced it under warranty.
That one lasts a week then stops working totally and leaves me stranded, again.
So, i bit the bullet and ordered a genuine one from ford, that came today, i fit that, and nothing, it doesn't work at all?!
The alternator is rewired, has an IGN + of 12v going to the D+ terminal and has a direct feed to the battery off the B+ terminal, both are tested and reading 12v, so no issues there.
It's not a heat issue, the manifold is wrapped up well, and the alternator has a heat shield round it, and it doesn't get too hot, i have put my hand up there after a blast, and although it's warm, it by no means untouchable.
So, am i missing something, or can nobody make a fucking alternator that works properly anymore?!
Voltage is 12v with engine off, 11.2 with it on. bosch 044, plus the ecu, all the gauges/lambda gauge ETC, all suck power and add up so without it being charged low 11's is what i'd expect.
there's no shorts on it, been through it loads of times, would pop a circuit breaker if it did (everything is circuit broken) bar the starter.
have you ran a wire straight from the alt up to the battery.. i had my alt tested and was all fine but the revs do drop a fair bit when everything switched on.. 90 amp one too.
mines the other way round voltage wise as i have around 11 with engine off then 13 odd when running..
But the 3 have worked for a while then died, i really can't understand why it needs the dash light, the whole lot is bypassed. It's getting a 12v ignition feed from elsewhere to the exciter.
If it's got 12v feed at the exciter and 12v at the main, there is no other way for it to know the battery light isn't on, surely?!
alternator warning light comes out of the alternator as earth it needs the resistance of the bulb in the system to energise the regulator once done it charges turning the light off by changing what comes out of the alternator to live the alternator will self excite if spun fast enough but will not charge at low rpm [put it back how it should be alternator manufacturers spend billions developing their systems]
just try and wire the batt light up an see wot happens mate, got nothin to lose. ive got a escort xr3i alt on mine an its never let me down. xr3i starters fit the yb aswell.
How does the bulb get an earth from there, where?! there's 2 wires into the alt, a + and another +?
Again, i'm not arguing, i am soooooo fucking confused. It IS still wired up on the ford loom, so is as it should be, does the ECU have something to do with it?
i never did fully understand it.
I find it massively strange that 1 of the alternator's worked perfectly for a while, then died, surely if the wiring was all wrong, that wouldn't of happened?
The battery light is part of the charging circuit, it excites the field windings by sending a live feed to them, it WILL however work without it, you just need to rev, which by the sounds of it you have been doing?
It's a very simple circuit, when the alternator is stationary, a switched live feed is sent via the warning light and earths, as well as exciting the field windings, at terminal 'D', when the engine is running it has positive charge, so say 13V+, hence two lives on the bulb extinguish it indicating all is well.
Martin
Martin
Ahh, Marty, starting to make sense, the D terminal is currently an ignition switched 12v (from behind the radio, as it happens)
I have no idea why it's like this, TBH, as it was something i wasn't involved with. the standard wire seemed to lose its output when we fitted the new engine/ecu/loom.
So, fuck knows how i can fix that?!
It makes no difference, although this does mean your HFS won't work!
Although it doesn't want to be a live feed you want a suitable bulb placed in the line (This could be what is what is damaging them)
On the OE setup the live comes from the instrument cluster, and then you will have a blue wire on the connector which is the same wire you see at the back of the unit.
The wire is well known for breaking, due to the heat from the turbo, so I suspect you have a break in this wire and the live is fine.
In which case just rewire this part, with a small ring connector to connect to the alternator.
FYI, the 'W' terminal is not used, this is for Tachos on Diesels mainly, and electronic chokes.
Martin
Martin
struggling with reality
The voltage should not get lower when the engine starts as this means the bat is NOT charging! This means that more things are coming on as expected ie fuel pump and ECU to run engine but the output from the alternator is not running them or charging the bat!
If you want to re-wire the field wire you'll need a ign live to one side of the charge warning light and the other side of the bulb wiring goes to your alternator,
this is earth whilst the alternator is not turning so putting the light on when you turn the ign on.
and it makes + voltage when the alternator is turning putting the warning light out as two lives dont make a circuit.
Make sure you have good clean earths as there just as important as the lives.
![Smile](https://passionford.com/forum/images/smilies/icon_smile.gif)
If you wire the D+ terminal up from behind the radio without a bulb or diode in line you will damage the alternator. What happens is when you turn off the ignition key the alternator is still charging until the engine RPM is zero. This can take 1 or more seconds. In that time the little exiter diodes are powering everything they are connected to ie in this case at least your radio. They can deliver approx. 10 Amps, that's including the current needed for the field winding. They will eventually burn out.
So fit a diode in the wire to D+ and Bob's your uncle.
If you wire the D+ terminal up from behind the radio without a bulb or diode in line you will damage the alternator. What happens is when you turn off the ignition key the alternator is still charging until the enigine RPM is zero. This can take 1 or more seconds. In that time the little exiter diodes are powering everything they are connected to ie in this case at least your radio. They can deliver approx. 10 Amps, that's including the current needed for the field winding. They will eventually burn out.
Thanks for the input chaps.
jonfoc
16
11-09-2018 05:35 PM
timsrs
22
24-09-2015 08:14 PM
