inlet manifold take off alloy weld on adaptors
Hi i need to add x 4 vacuum take offs to my inlet manifold on my rs turbo, im after the ones you weld on any one know where you can get them from, i can only find ones from demon tweeks but they are threaded and dont do them in alloy, my inlet manifold is not thick enough to tap a thread hence alloy welding the fittings in , think the vacuum pipe I.D is 5mm,
cheers daryl
cheers daryl
cossie fan (unluckerly)
im sure torques do them but are you sure demon tweeks dont! ive had weld on ones from them before in steel and im sure them asked me if im sure i wont steel ones for my fuel rail lol
cheers daryl
cheers daryl
If it's cast, there will be plenty to tap into.
Pnueumatic push fittings are very handy for this and come in a variety of threads. The two most common are M5 and 1/8" BSPT
Drill, tap then use hard nylon tubing to push into it. Either 4mm or 6mm OD.
This type of thing. Readily available anywhere that does air tools, compressors etc and very cheap.
http://legris-pneumatics.com/vit.asp?SubCat=2
Best thing about them is they are so cheap and easy to use. Just push in and out. No clips required if you can use them at both ends, and very easy to take back out again. The nylon hose is cheap too and available in different colours if you're into that
or what some people do now is use a little manifold for their vac/boost items that only requires a single takeoff from the manifold.
This type of thing, although it's bloody expensive. Should not be used for anything that flows air though like boost control
http://www.funkypower.co.uk/catalogu...d_product=5629
Its in a cast rs 16i inlet the fittings are going in the back so its not thick enough to tap a thread into, I could make some Aluminum female 1/8npt threaded and get them welded in and use threaded fittings.
Can't say ive ever seen a casting so thin it couldnt be tapped into for this sort of application.
But all you need is a bit of aluminium round bar, cut it, weld it on and drill/tap if you really think you need more thread engagement.
or simply cut some bits of flat alloy, whether round, square, flat bar, whatever and have it welded in then drill/tap as required.
You certainly dont need to be buying any fancy fittings.
Si B
12-09-2015 06:49 AM
