This can't be right?! (dealership invoice)
Old 20-04-2012, 12:06 AM
Chopshop85
Chopshop85's Avatar
Default This can't be right?! (dealership invoice)
One of the locals at my pub was asking me about a problem with his car (Zafira diesel turbo) Having trouble with the turbo, felt like it had very little boost compared to what it used to.
I said at a random guess it would be the actuator.
Turns out, it was the actuator needed replacing. So the local vauxhall dealership did the work and handed him the bill for £970!
That seems a bit steep to me? or is it like an engine out job or something?
Old 20-04-2012, 12:24 AM
Rax
Rax's Avatar
Faaaaaakinelllll for an actuator Holy cow,he should of got them to do some more work while it was there
Old 20-04-2012, 12:37 AM
S1
S1's Avatar
Could be the actuator only comes as part of the complete turbo assembly, it's not uncommon.
Old 20-04-2012, 01:54 AM
Eigdoog
±§~Quadzackular~§±
Eigdoog's Avatar
Rebuild was it?
Old 20-04-2012, 07:47 AM
Received 1,044 Likes on 998 Posts
I agree with that.
Did the bill include fitting too?
Old 20-04-2012, 09:27 AM
E980VTJ
E980VTJ's Avatar
most new vauxhalls are complete units,around £550 main dealer part,normally with vauxhall its a sensor that puts them into limp mode then it feels like very low boost,my old vec c had a forge dump valve and when the springs went in that vauxhall tryed saying it needs a new turbo,also they have a electrical boost sensor that failed only £10 but vauxhall wanted to change the turbo
Old 20-04-2012, 09:52 AM
DanW@FastFord
Spelling Club King!
DanW@FastFord's Avatar
Same with Euro4 Mondeo TDCis, the actuator fails and is usually a case of repairing a dodgy solder - Ford will only replace the entire unit.
Old 20-04-2012, 09:55 AM
_SpeedX_
_SpeedX_'s Avatar
probably a hose split! or loose.
also googling zafira diesel turbo no boost brings up tons of people same problem....
most say sensor or boost hose loose lol..
Old 20-04-2012, 02:43 PM
Chopshop85
Chopshop85's Avatar
Originally Posted by Glenn_
I agree with that.
Yeah that was the bill for the car back to working order.
I guess if its a whole unit that might be awkward to get to its not as bad as I first thought.
Obviously when he was telling me about it I just thought of the £70 my new actuator cost a while ago.
Old 20-04-2012, 03:25 PM
mark r
mark r's Avatar
family member had 2.0tdi zafira and egr valve went ,cost 1100 euro to replace
Old 20-04-2012, 08:44 PM
Brendan
struggling with reality
Brendan's Avatar
wow that's enough to make you walk like john wayne!
Old 20-04-2012, 09:41 PM
Mister G
Mister G's Avatar
Funnily enough, Vauxhalls also have a problem with the fuel pump going down due to a dodgy solder...
Old 20-04-2012, 09:45 PM
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
Isn't this a pretty common problem with Vauxhalls?
Old 20-04-2012, 09:50 PM
markk
markk's Avatar
Loving all the 'actuator' experts on here.
The 'actuator' on a modern diesel engine has nothing to do with wastegates
Old 21-04-2012, 02:41 AM
Rob Virgo
Rob Virgo's Avatar
What's it for markk
Old 21-04-2012, 06:31 AM
markk
markk's Avatar
Originally Posted by Rob Virgo
What's it for markk
It essentially controls the size of the turbine housing by moving the vanes in the vnt unit, by varying the gas flow onto the turbine you can have the effect of both small and larger turbine/turbine housings.
There really is no wastegate at all. To control the boost pressue you can use the vn's to speed up or slow the gas flow across the turbine thus reduce the quantity of air available
Old 21-04-2012, 07:14 AM
creator
creator's Avatar
As said its a full turbo unit on those and just as mark has described
Old 21-04-2012, 10:49 PM
Chopshop85
Chopshop85's Avatar
Well that has cleared that up for me.
I guess I was just shocked by the initial price. Knowing its a full unit being replaced I can understand the price a bit more.
bigryrs
28-03-2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
21-01-2016 09:54 PM
stevecfrst1
30-09-2015 05:18 AM
Daniel Howard
17
26-09-2015 12:39 AM
SmokeStoner
03-07-2005 05:11 PM
Quick Reply: This can't be right?! (dealership invoice)
