gauges that look like sapph instruments
Are there any gauges that have the same look as the standard sapph instruments, so with a black face, white numbers, orange needles and green illumination? Plus they need to be reliable, I don't what gauges that suddenly give false readings...
The VDO gauges look nice, but I want an oil pressure and temperature gauge in bar and °C, not in PSI and Fahrenheit. The same goes for the Autometer gauges.
For the third gauge I'm not really sure yet. I already have an AFR and boost gauge, so was thinking about an EGT gauge. But maybe that's a bit overkill as I never take it on a track and a voltmeter would be better?
cossie fan (unluckerly)
There alot cheaper than some i think plus they seem to be very good in mine. My cars cars mapped to 2.6bar and my boost gauge sits at dead on 2.6 mine came from merlin motorsport
It will be the high temp sensor your paying for! but ive never really got egt gauges as unless you mount the sensor in the manifold next to the head its more down pipe exhaust gases your getting a temp for
I thought the temperature directly after the turbo could be translated quite well to temperatures near the cilinder head?
The way I see it the AFR gauge tells go whether it's running rich or lean. But after a while of hard driving the temperatures will go up, even if it's running on a good AFR, so therefore the EGT is important to monitor.
Or am I missing the clue?
Mark RS
12-10-2015 06:01 AM
DavidK
27-09-2015 02:55 PM
wheelwizardrefurbs
22-09-2015 05:45 PM
