Car stuttering on boost at 4k rpm, (UPDATE: with pictures)
Needs Beer Tokens.....
Hi guys my FRST has been having an issue since i went zvh on it.....
It drives fine off boost and comes on boost fine too, but when it gets to 4000 rpm it hesitates and wont boost anymore with out stuttering , i also get a puff off black smoke out the back
Does this sound like overfuelling? i have whipped my plugs out and they are soot black, along with my exhaust, and the car is using ALOT of fuel aswell as smelling of it, since doing the zvh i have done the following mods:
1.8 zetec bottom end
rebuilt head
2nd hand kent cvh35 cam
New uprated fuel pump
2nd hand beige injectors
2nd hand bigger chip
The rest of the engine is as it was before, its off to power engineering for a set up on Saturday so wont be fiddling with fuel/boost will leave that too them, was just wondering if anyone's experienced problems like these and they couldn't be solved on the rollers (ie sensors etc)
Thanks alot Adam
rebuilt head
Thanks alot Adam
To be honest Glenn im not sure, thats the only thing im not clear on how to do
i put these plugs in:
http://www.burtonpower.com/chaqc59c.html
Thanks for your reply
Zee Germans are coming
just keep turning the boost up till it levels out with the fueling
only joking dont do that
sounds like its blowing the spark out and running a bit ritch
nothing you can really do till its set up
Worth sticking some standard RS turbo plugs back in it before the rolling road saturday do u think?
cant remember the gap you need
measure your old set and the new ones see what the difference is
And i when i had my cvh i used ngk plugs and never had this issue untill i went zvh.....fucking thing
All leads plugs and fuel filter are new, and were fitted with the engine 300 miles ago,
The chip is a 195 superchip which i have checked on my mates zvh (which runs beiges and a 195 and works fine on his.)
Took the plugs out today to fit some 071s and look what i found:
all 4 plugs look like this after under 300 miles
Overfuelling much?
Overfuelling much?
CabrioTurbo
01-08-2015 11:04 AM
Escortdriver1
31-07-2015 02:36 PM
