Help cosworth won't start.
Old 02-04-2012, 04:19 PM
Rsmat
300+
Rsmat's Avatar
Default Help cosworth won't start.
Right I've converted my 3dr to L8.. Wasted spark anti lag and launch control... Gone to start and it won't fire...everything has been done properly... When I flick the key I get a bang from the wasted spark... Then nothing... Could this be chip related... Has everything is done properly...?
Cheers Mat.
Old 02-04-2012, 04:28 PM
studabear
studabear's Avatar
when you removed the old coil did you join the wires from iirc the + side of the coil?
Old 02-04-2012, 04:42 PM
Rsmat
300+
Rsmat's Avatar
Yes mate.
Old 02-04-2012, 05:36 PM
Rsmat
300+
Rsmat's Avatar
Any more idea's...?
Old 02-04-2012, 05:44 PM
martysmartie
martysmartie's Avatar
I am sure you woulden't have, but you haven't used your L1 chip have you? (Kind of impossible as well seen as it can run Anti-lag)
Dosen't sound good though with it "Banging".
Martin
Old 02-04-2012, 05:47 PM
Rsmat
300+
Rsmat's Avatar
Martin
No mate new chip fitted... When you turn the ignition on it makes a quite bang down the exhaust.. I've got spark and it seems the fuel is there but won't even fire or start.
Old 02-04-2012, 05:49 PM
martysmartie
Thought as much, the backfire seems to be a common problem with the WS conversion, do you have the correct TPS and inverted the outer wires?
Martin
Old 02-04-2012, 05:51 PM
Rsmat
300+
Rsmat's Avatar
Martin
Yes mate that's all done.
Old 02-04-2012, 05:54 PM
martysmartie
CTS connected correctly, and pump priming on ignition? (The answer will almost certainly be yes to the latter due to the fact you say you have fuel)
Martin
daz1968
daz1968's Avatar
Did you also remove the capacitor from the old coil wiring, other than that you have got the phase sensor and crank sensor plugs the right way round as well.
Old 02-04-2012, 06:00 PM
Rsmat
300+
Rsmat's Avatar
Martin
Yes mate that's all good.
They should all be good mate has they haven't been touched.
Old 02-04-2012, 06:02 PM
martysmartie
Are the plugs wet? I would imagine it's just one slight wire etc in part of the conversion that is amiss. Have you gone through it all again?
Martin
Old 02-04-2012, 06:06 PM
Rsmat
300+
Rsmat's Avatar
Martin
I will check plugs... Yes have gone through it that's why I'm thinking chip maybe
Old 02-04-2012, 06:14 PM
GVK.
GVK.'s Avatar
Can the chip be put in the wrong way round?
Old 02-04-2012, 06:18 PM
martysmartie
Good point ^^, also have you installed the "WS driver board" correctly?
Martin
Old 02-04-2012, 06:19 PM
Rsmat
300+
Rsmat's Avatar
I've just took plugs out but this could be from trying to start it loads right..?
Old 02-04-2012, 06:22 PM
martysmartie
There 071's arn't they, they do look very carbonised!
Do you have any others you could try?
Martin
Old 02-04-2012, 06:29 PM
Rsmat
300+
Rsmat's Avatar
Martin
Yes I have some new ones... But these were fine until I tried starting it..
Chips in right way.. And wasted spark-board was fitted at MSD when Wong Rs had it fitted ( I bought the L8 off him)
Old 02-04-2012, 06:32 PM
dingla rs
dingla rs's Avatar
could be sparking at wrong time ?
Old 02-04-2012, 06:43 PM
Rsmat
300+
Rsmat's Avatar
What would cause that mate..?
Old 02-04-2012, 06:44 PM
daz1968
daz1968's Avatar
Have you got the extra wires in the correct plug terminals as I think you use different if with or without aircon on L8 as car it came off may have had aircon, just clutching at straws really but hopefully something simple that's got mixed on installation, also does rev counter register while turning over.
Old 02-04-2012, 06:47 PM
dingla rs
dingla rs's Avatar
isnt it running a cam trigger set up is that set up rite ? as you will geta spark an fuel but if its sparking at wrong time wount start is what i ment
Old 02-04-2012, 06:48 PM
Rsmat
300+
Rsmat's Avatar
TPS wires are swapped round for L8 and rev needle Doesn't move.
Old 02-04-2012, 06:51 PM
daz1968
daz1968's Avatar
The wires I mean are the 2 extras you put in the ecu plug, make sure they are same as added wires in ecu, also make sure new wires in ecu plug are fully home and making a connection. I am pretty sure rev counter should move a bit when cranking.
Old 02-04-2012, 06:55 PM
Rsmat
300+
Rsmat's Avatar
If you mean the 2 for wasted spark I will check tomorrow but I'm sure there in right mate but will go over it..
Dingla. No it's not on cam trigger mate.
Old 02-04-2012, 07:03 PM
saph4be
saph4be's Avatar
i sure i read on a wasted spark thread that you needed to swap the leads round!swap i for 2 and 3 for 4? i might be wrong though or was for there older w/s drivers?
Old 02-04-2012, 07:13 PM
JamesH
JamesH's Avatar
I had starting probs once converted to wasted spark, never got to the bottom of it
Old 02-04-2012, 07:33 PM
Rsmat
300+
Rsmat's Avatar
I just need to get it running.
Old 02-04-2012, 07:36 PM
Paul_RS
Paul_RS's Avatar
When i had this problem it was the wasted spark board.
Are you 100% sure you've soldered the board in correctly?
Old 02-04-2012, 07:38 PM
Paul_RS
Paul_RS's Avatar
Also what the fuck is going on with your name?
Old 02-04-2012, 07:40 PM
Sticky.
Sticky.'s Avatar
Daft question....
Are the lugs still on the bottom pulley Mat?
Old 02-04-2012, 07:41 PM
Rsmat
300+
Rsmat's Avatar
MSD did it and it came from a working car mate.
Fuck knows pal... I got name raped the other night....
Old 02-04-2012, 07:42 PM
Rsmat
300+
Rsmat's Avatar
Originally Posted by Sticky.
Daft question....
Yes mate... It's not daft atall mate.. I also thought and checked.
Old 02-04-2012, 07:43 PM
bad boy rs
bad boy rs's Avatar
Is the ecu definatly working ?
Rsmat
300+
Rsmat's Avatar
This is why I swaying towards chip/EPROM ..?
Old 02-04-2012, 07:44 PM
Rsmat
300+
Rsmat's Avatar
Yea must be mate other wise I would get spark or fuel right..?
Old 02-04-2012, 07:48 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
the additional wasted spark board is not eprom dependant ie you can fit the board to any cossie weber ecu even a standard one with a standard eprom
Old 02-04-2012, 07:51 PM
bad boy rs
bad boy rs's Avatar
I had problems with mine at first but turned out i had fitted the board wrong, have you got another l8 chip you can plug in ? If it came of a running car and the only theing different is the chip
Old 02-04-2012, 07:52 PM
Paul_RS
Paul_RS's Avatar
My original board supposedly came from a working car, but was goosed
Quick way to prove everything else is to put the coil back on the car. You only have to desolder 2 wires off the ECU IIRC.
If it starts, that proves the ECU/Chip/sensors etc are fine and its the board at fault.
This is how i fault found mine.
Give me two mins and I'll find out what wires need disconnected.
Old 02-04-2012, 07:57 PM
Paul_RS
Paul_RS's Avatar
Post #11 on this thread, least that'll help you fault find.
https://passionford.com/forum/genera...park-woes.html
Quick Reply: Help cosworth won't start.
