Had engine mapped on scs dyno
#281
I actually now see what Mike means, i have not read any replies until now as its boring LOL, he is saying on a STANDARD engine a .63 would need to run big boost to see 400bhp but with the .48 this fictional bollocks 385bhp is running safely because of the lower rpm peak....UNLESS u heavily modify the engine to accept the air flow the .63 can deliver to see 400bhp then would mean lower boost so safer.
where as 400bhp on the .63 is dangerously high boost.
Phil do you realise why the boost is lower on the modified engine? does it mean the turbo is making less air flow? or simply that the engine is now happily using even more air, so the plenum pressure drops even if the turbo is working just as hard as it was before? or maybe even harder!
#282
The .48 can flow safely the amount of air a yb can consume ie around 350 max however a .63 at 400 means higher boost due to the engine restrictions, the .63 would produce 400 at a lower boost if engine is heavily modified thus safer. Thats how i see it??? The .48 spools up really quick but runs quickly out of breath, i always likened the .63 like a t4 very lethagic but diesnt run out if puff.
#283
But mike is saying the T34.63 on a modified engine running 400bhp will fail in a short time.
Just because the plenum pressure is lower it doesn't mean it's safer, or that the turbo is working less hard
It just means VE has increased due to the engine mods so the engind uses more air, the turbo can still be pumping just as much volume of air even more so if the power has gone up. It can still overspeed.
I think the T34s in all forms are very well suited to relatively std spec engine. Start porting heads and fitting cams and you start to ask too much from a relatively small compressor and it will start to work too hard.
If you are at the stage where a std engine T34 is not enough, then there are far better options for turbochargers at that point than a T34.
#285
Caraholic
#287
*** Sierra RS Custard ***
In the case of a changing of back housing it does actually mean that for the same (in this case 385) BHP the turbo is now working less hard to flow that much air at the same rpm the engine was making that power at before.
The reason that the plenum pressure drops in the first place for the same engine at the same power level when you fit a larger exhaust housing is that the back pressure created by the turbo drops.
This drop in back pressure results in a drop in engine pumping losses which means that the engine can now make the same power with less boost.
If you look on the compressor map you will find that flowing the same air but at less boost will result in a drop in turbo speed.
#288
Caraholic
You keep making the assumption that the figures are made at equal rpm points when this is clearly not the case. The bigger turbine moves the entire powerband 500rpm higher, which means the 0.63 a/r is working harder due to the extra rpm range it is operating in.
I can't believe you cannot grasp this simple fact and instead are changing your arguement to suit how you "think" a 0.63 works, rather than looking at dyno sheets to actually see what it's operating range is.
track.focus'd
12-08-2015 05:53 PM
