General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Just wondered whats inside one really, i need -fittings welded into one but that got me thinking, can i just make one from scratch? Is there anything fancy inside one or is it just a empty pot?
You have 1or 2 in feeds on one side and 1 or 2 outlets on the other side with a plate separating it so the oil hits the plate and drops to the bottom of the tank through another fitting for a drain.
The plate goes from the top to the close to the bottom but not all the way to allow the air up out of the outlet fittings.
The other way is;
you have your 2 inlets at the top
one small drain outlet at the bottom
one large breather outlet at the bottom- and this large outlet pipe goes up inside the tank close to the top.
While we are on the subject where would the cam cover breather go on the seperator if i have it like below:
You don't need to breath from the rocker cover, just breathe from either side of the block and drain into the sump.
If you go onto GGR website and there's a good write up why not to.
