Cheapo pattern idle control valves on ebay??
The ones ive seen have worked fine, i find the springs are a little weaker though either side of the piston, worst case is to just take it apart and use the OE springs. The actual unit works fine.
Like Paul said they just take a little bit of time to get working perfectly.
I brought one a while back and the car run at 2000 RPM, it was James that suggested the spring. When I dismantled the spring on the aftermarket items aren't as strong as the OE item, thus the valve opens further.
I did try changing but then it done the opposite and run very slow.
James, do you change just the bottom spring, or both?
Martin
Martin
I have used them on zetecs and some have ran sweet after fitting and some revved high, but as mentioned unlike the OE ones you simply pop off the cap on most and turn the screw for a perfect idle
Martin
Martin
Martin
Martin
not a cossie but i replaced the one on our old 406 and it revved high/hunted.
i disconnected the battery for a few mins and after that it was spot on. same with a mate at works 306 the other week, was hunting/revvving so disconnect the battery and it was fine after
Martin
