help please will sierra 2.3d fit 1.8td p100
Hi all major problems my gearbox has broke on my beloved p100.will a sierra 2.3 diesel fit my 1.8 td.if so will there be any diffences thanks jack
big floppy donkey dick
i *think* you can put a normal petrol non V6 type 9 onto the TD bellhousing and will bolt up perfect and obviousley retain your TD specific starter etc!
from memory,
bellhousing is different shape and doesnt bolt on
input shaft on gearbox of 2.3 is longer than 1.8TD one
starter motor is in different place on 2.3 than a 1.8TD one
2.3d bellhousing (gearbox end is from another make, not ford g/box)
from memory,
theres a few p100`s breaking on ebay.
wont cost you anything to message them to find out cost of correct gearbox
http://www.ebay.co.uk/sch/i.html?_nk....c0.m270.l1313
i wouldnt do it with a 2.3 box as the ratios are horrid
unless you get the complete gearbox, machine the input shaft, play with clutch drive plate combinations, fit the 2.3 starter and wiring for the relocated starter motor, and clutch cable assembleys etc.
i would check the propshaft splines before you get the 2.3 aswell
it just isnt worth it in me eyes
if it just boils down to not wanting to spend Ł150 delivered
on the correct box then say so (i messaged a few people on ebay and 2 were this price)
markk
18
17-08-2015 05:19 AM
Jack and the Beanstalk
15-08-2015 04:27 PM
