Damaged Focus RS MK2
http://www.ebay.co.uk/itm/2009-09-FO...item2c62b1a311
Shouldnt cost too much to repair i thought, bargain possibly?
Same feeling as above. That would insurance repair all day long. Tred careful if it's taken the leg back could be a possible engine out job. There never as simple as they seem.
Hardly a bargain when you look at that one ,£18k, less miles,not on the hit list and not damaged .
puddy
be quids in
£15k is too much for that
st170 breaking
the leg is the bad bit it its over but the repair list would prob include
rack
hub
wheel
tyre
sill cover
wing moulding
headlamp
shock
lower arm
shaft
engine bearer??
gearbox mount?? they do like to break
maybe the box if the shaft went in
wing
bumper
paint
door or reshape it
maybe other bits as they make them to break so lugs off front panel? inner arch cover, various trims
if you knew of a breaking with rear damaged you may get that list for around a grand and chuck it all together but i expect it needs a jig if its been knocked on the head and not repaired
least the airbags are still in
TPM961
15-01-2018 10:50 AM
Cos500
16-09-2015 09:50 PM
